engine temperature??
hello everyone... i have a 97 cutlass supreme and i was wondering what the "normal" reading on the temp gauge is supposed to be? im not sure if my gauge/sensor is working correctly. when its "fully warmed up" it stays at the second line out of a total of four lines. to me that dosnt seem like its quite right? i know its hot because the heater blows hot.
The temp gauges in most of these cars are not to be taken seriously. If you would like to know what your car is actually running at, find someone with a scangauge and drive around with it plugged in.
Didn't a few of the 97's also get LQ1s
Jamie
In Lumina's and such, but '96 was the final year for the twin cam in the Cutlass.
mine has the 3100. would it be just easy enough to just replace the temp gauge coolant sensor to see if thats the problem? the car has 154k miles and the sensor is probably only like $10-$15?
Jamie
ohhh ok, I knew they were in the Lumina's had them cause I took the top end from a 97.
Jamie
NORMAL.
the 96+ cars use a 3 wire temp sensor which is not as fast reading the temp as the separate sensor on 95- cars. as a result, the readings are relatively broad and under informative. of course... this was due to people who thought the earlier style was too responsive and indicative of a problem....
okay so nothing to worry about. anyone know where i can get a coolant level sensor cheap?? mines turning the low coolant light on but the system is full haha
I've never had a bad one.... but I have had to clean them. try that. it is located on the passenger side of the radiator.
Mine does that too! I just waited till the light burned out :lol:
Just means I have to check it whenever I do an oil change.
Jamie
