meltboy1 Posted April 18, 2009 Report Posted April 18, 2009 I got the BOV welded on today and it seems to be working, except for the fact it seems like it is always open, like at idle, I put my hand in front of it and I can feel it pushing air out, and when I give it gase, I can feel it sucking in a little bit. I have it on the upper charge pipe and I T'd the small vacuum line from the cruise control. Should I go off a different line? it's a gen 1 DSM btw EDIT: Talked with someone and they said to go off the lines from the intake plenum, on the throttle body, so I Td off one of them and it works perfect now Quote
Garrett Powered Posted April 18, 2009 Report Posted April 18, 2009 I go off the back of the plenum Quote
meltboy1 Posted April 19, 2009 Author Report Posted April 19, 2009 ya, well it is still staying open at idle, and when i give it gas I am still feeling it suck in again, it worked at first but now it's doin it again...Are they adjustable? Quote
Garrett Powered Posted April 19, 2009 Report Posted April 19, 2009 they are supposed to open at idle, that is normal operation. so can you see the valve moving in there while squeezing in the cruise linkage and rev it up? Quote
meltboy1 Posted April 20, 2009 Author Report Posted April 20, 2009 ok, I didn't know it was supposed to stay open at idle, but shouldn't it close when I give it gas or is there not enough pressure in park? But ya, it definately opens, almost enough to knock my hat off...lol Quote
