GRANDFURY Posted August 31, 2003 Report Posted August 31, 2003 I want to change the rubber fittings in my dogbones because they r coming out of their place in the bone, If I just undo them will the engine fall or move??? I know all about tilting the engine and have done that but I just want to make sure before I do anything So my plan is to just undo them like in the tilting but take them all the way off am I on the right track???? Any help would be great Thanx Quote
Redfox340 Posted August 31, 2003 Report Posted August 31, 2003 No, if you remove the dogbones only, the engine won't go anywhere. But, it's hard to locate just the rubber inserts for them. Most likely you'll have to buy OEM full replacements or the FFP poly upgrade model. - Erik Quote
phantomFE3 Posted August 31, 2003 Report Posted August 31, 2003 and DB Performance is working on poly dogbones as well, and they'll be cheaper than FFP Quote
GRANDFURY Posted August 31, 2003 Author Report Posted August 31, 2003 so i cant just replace the rubber????? Do I have to replace the whole metal unit too???? I'm kinda new to this so sorry if I sound dumb Quote
Redfox340 Posted September 1, 2003 Report Posted September 1, 2003 But, it's hard to locate just the rubber inserts for them. Um... like I said, it's possible, but difficult to locate. If you need an instant fix buy a OEM, FFP, or (soon to be) DBP whole dogbone. - Erik Quote
