where does this sensor plug in at?
Ok so I have this sensor wire that I can't figure out where it goes it has two male ends and the wires are yellow and purple I think one end might go to the coil pack its a 96 3100 need to know ASAP
Sounds like crank sensor to me...Goes from the ICM to the crank sensor.
Ok I had a two wire harness that I had thought went there plugged in to the crank sensor and everything but I need to figure it out I just rebuilt it and don't want any mishaps on the first starts
the wire at the module with have three slots, the middle one empty, with purple on one side and yellow on the other.
the "red" connector is often unused and can be seen on 95+ cars and is for "magnasteer" variable assist option.
What is this other connector you speak of? how many slots and wire colors?
IS THE SELONOID THAT SITS BELOW THE COILS PLUGGED IN?
Yes purple on one side yellow on the other with a space on one end and yes the selenoid is plugged in sorry can't spell
idk a pic would help, only thing I thought of thought when I saw purple and yellow was VSS but I missed the 2 male end part so idk....
Its a two wire looks like a sensor extension wire about two and a half feet long the wires are purple and yellow on the one end it has a space in between I think one end of it goes to the icm but then where would the other one go that is in the same harness that goes to the oil level sensor
this is the crank sensor wire. it is completely separate from the rest of the car harness... with good reason... if needs minimal interference.
the 2 slot plug goes on a sensor on the lower rear passenger side of the block.
the 3 slot plug goes to the slot on the ICM.
p.s. make sure it is not routed against the egr of manifold. iirc it is routed towards the drivers side and through the area below the egr.
