Code 66 A/C
Addicted To Boost
it should be by the dehydrator along the driver side inner fender well
Well, I found the likely culprit of the A/C leak today while I had the radiator out of the car. One of the fittings on the driver's side near the radiator that thread together was hardly finger-tight! Hopefully thats the source of the leak.
Could you explain that in a bit more detail please? Or if anyone has any pictures of the orifice tube location, that would be great.
Thanks
-Nick
i am not real familiar with your car specifically but all the w-bods are set up "about" the same. i looked at some diagrams and it shows the orfice to be in the same place as my 95 CS but unlike my car they do not list it as a servicable part on GM genuine direct so you may have to replace the whole line that it is in. as i stated earlier it is located about 6-10" from the hydrator on the lower inner driver fender well. the line will get fatter where the orfice is. try looking it up at http://www.gmgenuinedirect.com they have great illistrations
