tdvs Posted April 12, 2009 Report Posted April 12, 2009 '95 Cutlass. When I turn the 4-ways on, the left front, left dash indicator, and both tail lights flash. The right front and dash indicator don't come on at all. When I turn the right turn signal on, everything on the right works fine. What's up with that? Quote
jtwmechanic Posted April 12, 2009 Report Posted April 12, 2009 got to make sure all the lights including the fender marker and quarter markers light up. if any of them are out it won't work correctly. Quote
GP1138 Posted April 12, 2009 Report Posted April 12, 2009 I'd lay money that if no lights are burned out it's the signal switch. Quote
95 vert Posted April 12, 2009 Report Posted April 12, 2009 Turn switch. Try pushing the 4 way switch up and down several times to "clean" the contacts. Quote
Brian P Posted April 12, 2009 Report Posted April 12, 2009 Yeah what he said My car does the same thing. Almost 200k on the original switch though so I'm not complaining. Quote
jake91 Posted April 12, 2009 Report Posted April 12, 2009 mine does that to. the flashers dont work and if you accidentallly touch the flasher switch at all the turn signals quit. i t just removed the flasher switch and put it in the glove box. lol Quote
tdvs Posted April 12, 2009 Author Report Posted April 12, 2009 Thanks all for the responces, except Jake. Shame on you. That's no way to fix things. If the engine quits working, are you going to just pull it out and through it in the glove box too? Seriously tho, checked the lights and all work. With ignition off, tried flashers. Same problem. Turned right signal on at the same time and flashers work right. Turned signal off and wiggled flasher button. If I push it to the left, all lights flash. I'll be getting into the steering column soon for another project I'm working on and should be able to find the problem with flasher button and turn signal switch in hand. Being a vert, I half expect my problem is corrosion. May also be tied to my cruise problem. Was cutting off when hitting a rough spot in the road. Not working at all now. Another question. Pulled a turn signal stalk out at the j/y yesterday as was indicated in an early post I read. Came out with the wires and plug in tact. B4 I pull mine out like that, is that really how it's done, or does that mess up a clip or something in the column? Don't want to add to my current problems. How does the stalk come apart? Have 2 and would like to take one apart to see what makes it tick. Sorry about rambling on, and thanks again. Quote
jake91 Posted April 12, 2009 Report Posted April 12, 2009 Thanks all for the responces, except Jake. Shame on you. That's no way to fix things. If the engine quits working, are you going to just pull it out and through it in the glove box too? shhh. dont say that the engine just went out 7000 miles ago, and i am going to fix it as soon as i get a job Quote
jtwmechanic Posted April 13, 2009 Report Posted April 13, 2009 you are better off pulling it in one piece Quote
