What could it be?
2002 grand am
Theft loc radio
The car got a boost and now the radio doesn't work..
I'm not an idiot and I know how to obtain the codes , all the fuses are good, but the display / unit won't
light up
Anything else it could be? I haven't seen it in peson yet but I'm heading there now.. It's my sisters friends car
If its not the theft lock thats locking it up then check for power behind the radio. Should be a orange constant wire, ignition power will probably not be there cuz im pretty sure this car gets it through data.
If your not getting power then double check the fuses and try running a lead from the ignition switch over to the orange wire. If the unit is getting power and still isnt turning on it probably fucked.
Fuses on the passenger and drivers side of the dash, plus under the hood. Check them all.
the code for each vehicle anti theft loc is different so unless you have the original then it will cost you about $100 to have it recoded, if that's the problem, like has already been mentioned check fuses again and not just radio fuses. seriously doubt a wiring issue. is the theft loc light on?
there is a write up on here how to call in and get the codes.. The red light is flashing on the deck but nothing else lights up all the fuses are good
this is a monsoon deck with the cd and tape player, the bottom buttons and the red around the tape deck light up but nothing else does... all the fuses are good, i think im just going to install an aftermarket deck if i cant fix it
i'd rather have an aftermarket anyway. by the way, that's one sharp 89!
Sounds like something internally in the radio then cuz its obviously getting power. The display and shit will light up if its in locked mode you just cant do anything with the unit.
fixed! it was the feed comming from the "radio batt" fuse. thanks guys
same car as the one you did rear brakes on today?
