So I have been trying to track down some poly sway bar bushing's and have had no luck. I looked around on here and on energy suspensions website.
I want them for a 95 Z34 Monte. I believe my sway bars are the largest they get because of it being a z34. 34mm up front but can't find a 34mm bushing for where it mounts to the subframe. Not sure if that's the right size but if someone can help me out and possibly have part numbers.
I am looking for the front and rear.
Oh yea and I know there are 2 people on here that did the control arm bushings. If you happen to chime in what was the exact year cutlass that you ordered the bushings for and they worked on the w-body. Part numbers for this also will be greatly appreciated.
thanks
Dave
So I guess you are telling me that all these sizes are the same for my z34. I seen those threads and all but wasn't sure if it was the same sizes for my Z. I know even with everything being a w-body stuff is still different between the cars.
thanks.
All you have to do is measure the diameter of the bar, and find bushings that will work with what you measured on their website, and theres your new bushings.
Got the two sets of ES bushings for the front last night.
I also got the outer mounting ES bushings for the rear sway bar. Is there anything that I can use for the inner mount on the rear sway bar?
Sorry, I didnt have the time to give you more then just the threads I had saved in my browser. As far as the inner bushings for the rear sway bar I have yet to locate anything yet.
Yea I figured the inner didn't have anything. Thanks for the links.
