Addicted to eaton Posted April 6, 2009 Report Posted April 6, 2009 Ok here is the progress of the gtp so far! Got motor-done pulled old motor out!- Done a picture of what a oil pan looks like when I rod comes in contact with it! Anyways filled it up with fluids let it run and topped it off with 50/50 water anti freeze I drove it to town, washed it, drove around for awhile. everything was fine drove back home and I noticed steaming. I rubed it off as from the car was but still looked everything was normal. Drove it back to town, to eat, and around I decided to get on it one time. And it frankly ran like shit, died out a little I figure I will check plugs and coil first. Then the heat went cold and it started heating up. It was very low on water I never let it get above 210. Put coolant back in it. It didn’t feel like the top radiator hose had water in it! How do I know if my t-stat I stuck!? Quote
White93z34 Posted April 6, 2009 Report Posted April 6, 2009 sounds like you just didn't bleed it out properly. drill a small hole in a t stat to make bleeding WORLDS easier. Quote
Addicted to eaton Posted April 6, 2009 Author Report Posted April 6, 2009 How would i bleed it properly? why would it have ran 40-50 miles with out over heating Quote
White93z34 Posted April 6, 2009 Report Posted April 6, 2009 run the engine keep the bleeder screw on the t stat housing open till coolant comes out and no more air does. Quote
Addicted to eaton Posted April 6, 2009 Author Report Posted April 6, 2009 so i need a strait line off collant peeing out? Quote
GP1138 Posted April 6, 2009 Report Posted April 6, 2009 so i need a strait line off collant peeing out? Yes. Peeing out. Quote
Addicted to eaton Posted April 6, 2009 Author Report Posted April 6, 2009 i think i got it. Now about that WOT car runs like shit thing lol Quote
AL Posted April 6, 2009 Report Posted April 6, 2009 Its teaching you to drive responsibly on public roads... So I dont see a problem Quote
Addicted to eaton Posted April 6, 2009 Author Report Posted April 6, 2009 Its teaching you to drive responsibly on public roads... So I dont see a problem Al, I really understand what your saying. But I have to defend myself, Its nature. I have never had a wreck, or accident of any sort. And FWIW, Its really very hard for me to not go fast in a faster car. Everynight on my drive home I drive slow like a granny, and think to my self “Ill drive like this all the time there is no reason to hot rod my car” Then the next day I do it, it just happens, its almost like im addicted to 0-60 in 6 sec’s its really something I wash I could stop doing. I really hate treating my car like that but I just cant stop. Any help? Quote
AL Posted April 6, 2009 Report Posted April 6, 2009 Yah, I know how you feel... I drive the same way... I like watching the speedo and tach race... I was just giving you shit... It sounds like your running lean up top tho... Check fuel pressure and check for vacuum leaks... Also let us know how the plugs and wires and coils look. Quote
jtwmechanic Posted April 6, 2009 Report Posted April 6, 2009 lim leaking internally? check your plugs for signs of water in cylinders, also make sure not milky under oil fill cap. sounds a speed demon has possed your foot like it has mine wahahahahahaha agreed when servicing the coolant system these cars have to be BLED!!!!! and no offense, but don't drill any holes in your thermostat just take your time a bleed it properly Quote
Addicted to eaton Posted April 6, 2009 Author Report Posted April 6, 2009 im thinking its a vacume on the supercharger. as it does it when crusie is set and it starts to go up a hill. Quote
Addicted to eaton Posted April 7, 2009 Author Report Posted April 7, 2009 Pluged it in at work and it said miss fire one number 1. Put a new plug wire on and she ran great! Wooooot! Quote
