cperna15 Posted April 6, 2009 Author Report Posted April 6, 2009 well i can but a new comp from harrys u-pull it for $4 but i just would hate to make the 2 hour trip there for nothing ....whats the highst crusing speed i would wanna go, like i usally keep it at 3500 rpms is that bad or can i go higher? Quote
GOT2B GM Posted April 6, 2009 Report Posted April 6, 2009 Had my old 93 Z34 do something similar to this. It would only give me 2nd and 3rd gear. Turns out the VSS harness had a short in it, which caused the trans to go into "limp mode" because it didn't know how fast the car was going at any given time. Quote
jtwmechanic Posted April 6, 2009 Report Posted April 6, 2009 if you end up going to salvage yard go ahead and get the harness and sensor to save other trips later. if you are dealing with a short they can be very difficult to find and harness replacement would be the best route to go there. although i don't think either would make you loose first maybe od and on those year cars didn't they use a modulator valve, front side of tranny with vacum line attached from it to upper intake. just want to make sure an oversight isn't your problem. 90% of all problems can be determined visually. Quote
cperna15 Posted April 7, 2009 Author Report Posted April 7, 2009 UPDATE.... the tcc fuse blew and its all good now exept overdrive i dont have overdrive, any ideas? Quote
Crazy K Posted April 7, 2009 Report Posted April 7, 2009 UPDATE.... the tcc fuse blew and its all good now exept overdrive i dont have overdrive, any ideas? have you tried restarting the car to see if overdrive then returns? I've had to do that before... Quote
cperna15 Posted April 7, 2009 Author Report Posted April 7, 2009 what do you mean by "restarting"? Quote
Crazy K Posted April 7, 2009 Report Posted April 7, 2009 basically... turn car off. re-start. see if it still lacks overdrive. there is an "overheat" limp mode where the PCM locks itself out of overdrive, and torque converter clutch lock-up. this has happened several time in my 95 CS, and it is discovered to simply not up-shift with no further explanation. I had simply turned the car off and then turned the key on while rolling (fast enough I don't even need to re-start), this rests the PCM and allows Overdrive and TCC functioning. I advise everyone to add an external transmission cooler, as adding one has virtually stopped all the issues that the 95 has had. Quote
jtwmechanic Posted April 7, 2009 Report Posted April 7, 2009 Crazy K is absolutely right about the cooler. lots of od trannies share this same problem, i had an older, well a 90 GTA that overheated the tranny and lost od for about 100 miles!!! but i still think it is electrical. Quote
cperna15 Posted April 7, 2009 Author Report Posted April 7, 2009 i have tried that and still no good, the car now has first second and third and it shifts on its own, just no overdrive. Quote
cperna15 Posted April 8, 2009 Author Report Posted April 8, 2009 okay well i figured out what was wrong, the cruse controll fuse was blown...who would of known Quote
Crazy K Posted April 8, 2009 Report Posted April 8, 2009 okay well i figured out what was wrong, the cruse controll fuse was blown...who would of known WOW! Quote
jtwmechanic Posted April 9, 2009 Report Posted April 9, 2009 to bad you didn't see that when you found the tcc fuse Quote
jtwmechanic Posted April 9, 2009 Report Posted April 9, 2009 had no idea that fuse would do that to od Quote
cperna15 Posted April 9, 2009 Author Report Posted April 9, 2009 well i knew about the cruise control fuse cause i took that one out to put in the tcc, BUT i had no idea that had anything to do with OD Quote
