chevy Posted March 28, 2009 Report Posted March 28, 2009 got a 93 lumina Z34 and everytime i make a left turn the car stutters like crazy and almost stalls could this be a fuel problem? no codes are being thrown. the car also stalls out of the blue somtimes somtimes i will start it up then wont hold and idle then i will start it up again and it will run fine. Quote
Ned Flanders Posted March 28, 2009 Report Posted March 28, 2009 How much gas do you have in the car? Does it still do it when you have a full tank? Quote
Robby1870 Posted March 30, 2009 Report Posted March 30, 2009 Sounds to me like it could be the IAC (idle air control) valve. Could also be the coil packs and/or ICM (ignition control module). Quote
Brian P Posted March 30, 2009 Report Posted March 30, 2009 does it feel like the transmission is slipping out of gear? Usually when the trans fluid is low, left turns will push the remaining fluid away from the pump pick-up (filter inlet) and cause slipping or stuttering. Check your fluid according to your owners manual's procedure and add if needed. Quote
chevy Posted March 30, 2009 Author Report Posted March 30, 2009 does it feel like the transmission is slipping out of gear? Usually when the trans fluid is low, left turns will push the remaining fluid away from the pump pick-up (filter inlet) and cause slipping or stuttering. Check your fluid according to your owners manual's procedure and add if needed. It only does it on left turns and not right somtimes when i take a left turn the service engine light will come on then go off? and somtimes if the wheel is turned all the way left it will stall (when making a turn) and when you making the turn it jump to 2k then drops to 1k then when the car is stright it drives fine Quote
blakngold4life Posted March 31, 2009 Report Posted March 31, 2009 I had something similar and it was just bad gas. When I had my old motor in it stalled when making left turns sometimes, do a little research on the "phantom stalling" that these motors are prone to if that ends up being a separate issue. Quote
CSI_MuNkY Posted March 31, 2009 Report Posted March 31, 2009 :willynilly: :willynilly: :willynilly: :willynilly: :willynilly: My car is doing the same damn thing and I can not figure it out! Mine started to die on left hand turns only, then it started blowing the 40A IGN SW1 fuse under the hood. I am swapping out my steering column this week Jamie Quote
GOT2B GM Posted March 31, 2009 Report Posted March 31, 2009 Friggin Nascar junkies, wore the car out with left turns. Quote
CSI_MuNkY Posted March 31, 2009 Report Posted March 31, 2009 FWIW, mine does it no matter how much gas is in the tank My signal switch was starting to act up when I took the car off the road My gas gauge was not working at all when I moved the car from my Ex fiance's to the new storage place. If my new column doesn't fix it, I'm going to be dropping that gas tank Jamie Quote
Captain Ficho Posted March 31, 2009 Report Posted March 31, 2009 What do you mean the car isn't running right on left turns? That's a good thing, if your car ran right when you turned left it would be going the wrong direction. Quote
CSI_MuNkY Posted March 31, 2009 Report Posted March 31, 2009 What do you mean the car isn't running right on left turns? That's a good thing, if your car ran right when you turned left it would be going the wrong direction. Says the guy who's car can't run properly sitting still! Jamie Quote
Captain Ficho Posted March 31, 2009 Report Posted March 31, 2009 What do you mean the car isn't running right on left turns? That's a good thing, if your car ran right when you turned left it would be going the wrong direction. Says the guy who's car can't run properly sitting still! Jamie Runs great when it's moving though! How backwards is that? Quote
GOT2B GM Posted March 31, 2009 Report Posted March 31, 2009 My car doesn't run left on right turns. But seriously, in your case, I'd say fuel delivery related (weak pump?) Quote
Robby1870 Posted March 31, 2009 Report Posted March 31, 2009 ^ Pump's in the center of the tank though. Not saying that's not it, just making discussion. What about crank sensor wire grounding itself out to the block? That happened to me once. When I would take off from a stop the wire would move a little and ground itself out and stall the car. Just a thought. Quote
CSI_MuNkY Posted March 31, 2009 Report Posted March 31, 2009 What about crank sensor wire grounding itself out to the block? That happened to me once. When I would take off from a stop the wire would move a little and ground itself out and stall the car. Just a thought. Worth checking! I haven't checked mine yet... Jamie Quote
GOT2B GM Posted March 31, 2009 Report Posted March 31, 2009 have fun with that on a LQ1 with an auto HA! Pretty much gotta lower the right side of the subframe and pull the alt to do that. Quote
jtwmechanic Posted April 4, 2009 Report Posted April 4, 2009 you have got issues inside the steering column itself. probally right behind the wheel where the signal switch is located. Quote
CSI_MuNkY Posted April 5, 2009 Report Posted April 5, 2009 you have got issues inside the steering column itself. probally right behind the wheel where the signal switch is located. What is it that brings you to that conclusion?? I hope your right cause tomorrow I'm swapping my column and signal switch to hopefully fix this problem on my car. Jamie Quote
chevy Posted April 5, 2009 Author Report Posted April 5, 2009 Well still isnt fixed and the car stutters and stalls everytime i hit the gas also it i notice when it park it wont rev higher then 3k? Quote
CSI_MuNkY Posted April 5, 2009 Report Posted April 5, 2009 Well the rev limiter in park is set around 3-4k, so unless your car is chipped, that's normal. Your problem still sounds the same as mine. Your car has been doing everything mine has. I bet eventually your "IGN SWCH 1" fuse blows too I'll keep you posted on what happens with my column swap Jamie Quote
chevy Posted April 5, 2009 Author Report Posted April 5, 2009 My car has got to the point where i cant even drive it i took it up the street the car wouldnt stop surging and as soon i i took my foot of the gas it would stall. Its real damn annoying :mad: Quote
jtwmechanic Posted April 5, 2009 Report Posted April 5, 2009 your prob sounds diff than GTP_MUNKY his is only on left hand turns and yours is all the time. had a 97 4.3 vortek with same prob ended up being the throttle positioning sensor. Quote
chevy Posted April 5, 2009 Author Report Posted April 5, 2009 I have a spare tps sensor i going to try tommorow. Quote
chevy Posted April 6, 2009 Author Report Posted April 6, 2009 What sensor is above the oil fliter? on 3.4. i noticed today everytime i shut the car off its spitting oil out on to my oil fliter. Quote
