SrMichi Posted March 28, 2009 Report Posted March 28, 2009 Well My dad let me borrow his 02 Golf TDI 5 speed because im takng my car to the body shop on monday. i want to be try to fix his messed up rims since he letting me borrow his car for a week. any ideas on what can be done to make them look any better? Front rims this last one is the same for both rear wheels Quote
1990lumina Posted March 28, 2009 Report Posted March 28, 2009 With a TON of work you can probably make them look better - but the aluminum looks very corroded. Quote
Cully77 Posted March 28, 2009 Report Posted March 28, 2009 You looking to do it yourself? there's those "wheels america" places that charge a flat rate per wheel, which might be a good option in your case. Quote
SrMichi Posted March 28, 2009 Author Report Posted March 28, 2009 You looking to do it yourself? there's those "wheels america" places that charge a flat rate per wheel, which might be a good option in your case. I was but i guess ill let it be. Maybe if he sells me the car in the future ill save up and fix them or buy new ones. Quote
jeremy Posted March 28, 2009 Report Posted March 28, 2009 I wouldn't waste the energy that would be required to try to restore those wheels Quote
GOT2B GM Posted March 28, 2009 Report Posted March 28, 2009 If anything, just have them mediablasted and powdercoated. I wouldn't mess with trying to refinish and polish by hand. Quote
THe_DeTAiL3R Posted March 28, 2009 Report Posted March 28, 2009 You looking to do it yourself? there's those "wheels america" places that charge a flat rate per wheel, which might be a good option in your case. That's what I was thinking. Those type of places charge what like $100-150 a wheel? As Matt mentioned it's too much work to do on your own so that would be the better option, if you think they are worth spending money onto. I personally think there are WAY COOLER rims for VWs that you can buy. Quote
jake91 Posted March 29, 2009 Report Posted March 29, 2009 i say just have at them. you cant make them worse. what the hell happened to them Quote
Dirk_Diggler Posted March 29, 2009 Report Posted March 29, 2009 I think your best bet would be to refinished the lip area by hand , mask the rivets off and coat the middle with automotive paint of some sort. Wont take much but would look nicely detailed when finished. Quote
SrMichi Posted March 29, 2009 Author Report Posted March 29, 2009 i say just have at them. you cant make them worse. what the hell happened to them He washed his car and put some spray cleaner on them and he must have let them dry up and the clear coat came off then i guess they got raped by salt Quote
SrMichi Posted March 29, 2009 Author Report Posted March 29, 2009 You looking to do it yourself? there's those "wheels america" places that charge a flat rate per wheel, which might be a good option in your case. That's what I was thinking. Those type of places charge what like $100-150 a wheel? As Matt mentioned it's too much work to do on your own so that would be the better option, if you think they are worth spending money onto. I personally think there are WAY COOLER rims for VWs that you can buy. ill just let them be anyways it needs some new tires so ill try to get some package with rims and tires IF he sells me the car in the future. Quote
cperna15 Posted April 2, 2009 Report Posted April 2, 2009 well if you want you can get some steel wool and a scuff pad and clean them up as much as possiable and then goto autozone and get some WHEEL PAINT and paint them , id do them graphite grey Quote
