GP1138 Posted March 26, 2009 Report Posted March 26, 2009 So, the previous owner(s) of my 'vert broke one of the plug wire caddies (whatever the fuck they're called) on my 3.4L DOHC. The center rear to be exact. I have a replacement wire from my '94 but the plug wires are routed oddly, what's the easiest way to replace the rear plug wires? Removing the power steering pump? Quote
5speedz34 Posted March 26, 2009 Report Posted March 26, 2009 I just called your cell. What the hell is a plug wire caddie? I'm not trying to take a jab at you but what are you talking about? Quote
ManicMechanic Posted March 26, 2009 Report Posted March 26, 2009 The plastic routers for the plug wires. I broke one too. Quote
5speedz34 Posted March 26, 2009 Report Posted March 26, 2009 So your question only has to due with the plug wire routing not the caddie? Quote
ManicMechanic Posted March 26, 2009 Report Posted March 26, 2009 It's kind of a bitch in these cars... Quote
5speedz34 Posted March 26, 2009 Report Posted March 26, 2009 It's kind of a bitch in these cars... Somewhat but it's not bad. I want john to clarify then I will post. Quote
GOT2B GM Posted March 26, 2009 Report Posted March 26, 2009 you should be able to remove the plug wires without removing the PS pump Quote
5speedz34 Posted March 26, 2009 Report Posted March 26, 2009 you should be able to remove the plug wires without removing the PS pump Well from the factory the stock rear wires where routed underneath the cam carrier, and between the intake manifold and the ps pump. Rerouting them can be a pain, I unbolted the PS pump so I had easier access to maneuver the wires down there. Quote
