Drummer Posted March 24, 2009 Report Posted March 24, 2009 The second time your press the lock button is the horn suposed to toot like once or the lights flash once, because mine doesn't do that, not sure if it's suposed to or not but i got curious. Thanks. Quote
dodgethis Posted March 24, 2009 Report Posted March 24, 2009 I am trying to install one in my car, I know that on a chevy blazer, and anything Chevy OEM It should. It Should honk after the second button has been pressed. The first button press would be to lock the door you just got out of or "unlocked" and then locking the car again or pressing the button for a second time would automatically lock all 4 doors all around. The honk would basically mean the car is secured. Lights would flash once with honk. Quote
Drummer Posted March 24, 2009 Author Report Posted March 24, 2009 Well the second time all doors lock but there's no toot or lights blinking. is there a fuse that i could replace or is part of the RKE junk? Quote
jimmyfloyd Posted March 24, 2009 Report Posted March 24, 2009 I believe the horn honk is able to be changed via a series of steps on most GM vehicles. Not sure what those steps are though. Quote
dodgethis Posted March 24, 2009 Report Posted March 24, 2009 What I probably would do is one of two things. 1. I would find the RKE brain and see if the wiring and especially the wiring for the headlights are even wired to the crkt. 2. I would (just for S and G 's ) I would re-sync or reprogram your fobs to the rke to see if it would help reset the rke brain and put it to normal configuration 2.5. If you reset the rke and reprograms the fobs and didn't show any lights with the horn. I would un hook the battery from the car, and let it sit without power. It is more than likely you will have to reprogram the fob's to the car, but I say this in the event there is residual power to the rke and it is still "remembering" the old setting to the RKE brain On another note, I highly doubt the RKE is junk. I mean if all i suggested doesn't work, who cares if your headlight dont light up, hell at least the car will honk and you can at least distinguish between if the car is locked or unlocked by hitting the button. I wish I had keyless entry Quote
Drummer Posted March 24, 2009 Author Report Posted March 24, 2009 What are the steps to reprogramm the RKE I searched in the forum but couldn't really find any thing close. Quote
carkhz316 Posted March 24, 2009 Report Posted March 24, 2009 No. It won't honk. Not now or ever, unless you wire in something extra, i.e. another keyless setup, or equivalent. There's nothing in the owners manual about it, nor is there any wiring tied to the horn from the RKE module. At least on the monte's and luminas. Quote
HolyZ34 Posted March 24, 2009 Report Posted March 24, 2009 5th gen montes with the keyless don't honk or have the lights blink at all when you use the keyless entry to lock the doors. Quote
Drummer Posted March 26, 2009 Author Report Posted March 26, 2009 No. It won't honk. Not now or ever, unless you wire in something extra, i.e. another keyless setup, or equivalent. There's nothing in the owners manual about it, nor is there any wiring tied to the horn from the RKE module. At least on the monte's and luminas. Thats kinda what i was thinking but i figured i'd ask anyways. thanks for the info. Quote
