Shaft lube that is. Steering to be exact. (I know what you were thinking).
My steering wheel is clunking, so I'm assuming the steering shaft dried up. How would I go about re-lubing it up? This on my 1995 Regal with 195k miles btw.
I posted in this? Did someone delete my post? Why?!
I was under the impression the first-gen columns don't have that issue and can't be lubed.
EDIT: How does that not contribute to the thread? Unless someone can come in a say otherwise or elaborate on my statement. Either way, after reading that link, I'm pretty damn sure the 88-93 (94 for Lumina's) doesn't have that sliding shaft setup. I think its a solid piece, and it might be the same way for the 94+ cars although I've never had a column out of one of those.
Your original post did not contain any of the information you just posted. All it said was "I don't think our columns have this issue", which does not answer the original poster's question in any way.
Our Columns should not have that issue.
all the gen 1 and 1.5 cars basically have the same intermediate shaft.
there is a sliding joint so the shaft can change length, and that it pinned together and has a spring clip inside it, but should not be the source of an noise or problems.
What other issue can it be? I her a faint clunking noise while turning my steering wheel, particularly while turning slowly as I would while getting out of a parking spot.
Steering rack bolts loose? Subframe bolts loose? Worn subframe bushings?
