CutSupreme93 Posted March 21, 2009 Report Posted March 21, 2009 i have a 1993 cutlass supreme 3.4 dohc, what other years and car models can i get another transmission from? Quote
jake91 Posted March 21, 2009 Report Posted March 21, 2009 91-97 lumina cutlass montecarlo grandprix any car with the 3.4 Quote
CutSupreme93 Posted March 21, 2009 Author Report Posted March 21, 2009 alrighty thanks for the help, now is my transmission the 4t60 or the 4t60e? Quote
Addicted to eaton Posted March 21, 2009 Report Posted March 21, 2009 91-97 lumina cutlass montecarlo grandprix any car with the 3.4 Very wrong info I think a grand prix, cutlass, lumina Any car with a 3.4 but i think only 1991-1993 You have a Vacume transmission not E Quote
jake91 Posted March 21, 2009 Report Posted March 21, 2009 oh sorry i forgot that they switched it from vacume to electronic thank you for correcting me Quote
spiderw31 Posted March 21, 2009 Report Posted March 21, 2009 Actually IIRC, he would have the -e tranny. I believe that the even the 3.1 got the -e in '93, but all 3.4s got it from day one. At least my '92 has it for sure, so I believe that your first post is correct jake. Quote
Andrew Posted March 21, 2009 Report Posted March 21, 2009 oh dear, so many noobs posting bad info... you have the 4t60-e. they had some changes over the years, and i think 93 is a 93 only type year. maybe a 92 or 94 would work as well, not sure. Ken or Manic would know. Quote
GOT2B GM Posted March 22, 2009 Report Posted March 22, 2009 x2 All LQ1's (91-95) came with 4T60-E's I'm not sure if the 96-97 had the 60 or 65.... 93 was the first year the 3.1 MPFI got mated to the 4T60-E So I will say you can use a trans from a 93 W car, LHO or LQ1 Quote
jman093 Posted March 22, 2009 Report Posted March 22, 2009 96's and 97's still had the 4T60-E (thank God). Quote
AL Posted March 22, 2009 Report Posted March 22, 2009 I have a trans from my 93 DOHC car... Wanna buy it? http://www.w-body.com/forum/index.php?topic=76015.0 I was told that the 94-97 trannys are different than the 91-93 Trannys... Quote
carkhz316 Posted March 22, 2009 Report Posted March 22, 2009 96's and 97's still had the 4T60-E (thank God). Correct-a-mundo. Even the 3.8 didn't get the 4T65E until 1998. 93 was the first year the 3.1 MPFI got mated to the 4T60-E I thought that '91 was the last year of 4T60/ TH440? Quote
AL Posted March 22, 2009 Report Posted March 22, 2009 3.1 cars still got the 4T60 until 93... 94 they got the E Quote
Crazy K Posted March 22, 2009 Report Posted March 22, 2009 EVERYONE OF YOU NEEDS TO LEARN!!!! All LQ1's (91-95) came with 4T60-E's FALSE! You forgot about the 284! <3 91-96 3.4 LQ1s used the 4t60e and the 4t60e DOES USE a vacuum modulator. 97 3.4 LQ1s used the 4t65e no vacuum modulator. 1993 4t60e is a 1993 direct swap only. 91-92, and 94-95 will substitute if you "swap the case wiring" (or re-pin your external connector) 96 may fall in the same boat, but there are other differences to the internals. ALSO, the donor trans must come from a 3.4 car or you will have the wrong gear ratio. Quote
GOT2B GM Posted March 22, 2009 Report Posted March 22, 2009 But the 3.1 93 4T60E will work with a LQ1, besides the gear ratio differences I was more or less kinda right. Quote
AL Posted March 23, 2009 Report Posted March 23, 2009 I am traveling to Chicago area on April 5th... If you wanna buy my trans, I will bring it to you if your around that part of IL Quote
CutSupreme93 Posted March 23, 2009 Author Report Posted March 23, 2009 I am traveling to Chicago area on April 5th... If you wanna buy my trans, I will bring it to you if your around that part of IL Is there anything wrong with it? Quote
AL Posted March 23, 2009 Report Posted March 23, 2009 Nope... I drove out here to Nebraska from Ohio on it and put 500 miles on it out here before it was parted out... The drivetrain of the car was/is perfect but the frame rusted out and brake/fuel lines under the car were rusting through and my support arms in the rear were so fragile I could bend them by hand... So that why I parted it out... Quote
Crazy K Posted March 23, 2009 Report Posted March 23, 2009 3.1 cars still got the 4T60 until 93... 94 they got the E FALSE on the 3.1mpfi, 93 was the first year to get the 4t60e, 92 was the last for the 4t60 the tranny you are offering is from a 93 3.4 correct? Quote
CutSupreme93 Posted March 23, 2009 Author Report Posted March 23, 2009 so about how many total miles are on it? and its for the 3.4 right Quote
AL Posted March 23, 2009 Report Posted March 23, 2009 Yes, 93 3.4 GP 157k... I have youtube videos of the car... The engine bay was spotless when I bought it... Quote
