Moon Roof Leaks
Ok It rained and when I went in reverse water poured on my lap. There is a hose running from the moon roof to the driver side door, right. I think it might be clogged or removed.
Question: What do i need to do to remove the head liner to get to the hose and do i need "glue" to put it back?
Thanks
Headliner shouldn't be glued. You will need to remove the sunvisors, all the trim pieces that touch the edges of the headliner (If it looks like it holds it up, then it does) The trim around the moonroof, plus there should be 1 or 2 plastic clips near the back window that will need to come out too. Once thats done, its just a matter of maneuvering it out of the car.
Drop the headliner, then take compressed air and blow each of the lines out. A long piece of copper house wiring works as well for a pipe cleaner.
If it still leaks it could be the weather stripping, but our roofs are made to leak a little bit (hence the drain tubes). How is the actual frame that the glass is bonded too in? I know mine was rusted to shit.
Thanks guys. Yeah the class frame has some rust on it. The head liner is soaked. Let you know how it turned out.
