I have a 95 Cutlass Supreme Convertible ... my driver's side Fog Lamp must have taken a stone .. broken. Does anyone know if the Fog Lamp lens from the 4 door Cutlass Supreme fits the convertible lamp assembly. I believe the assemblies are not interchangeable (only coupe and convertible are I believe). But it appears the lens is the same size. I can't get just a lens from the local Chevy dealer .. just the whole assembly at $132 each. I found several 4 door Cutlass Supremes in a local junk yard that I can pull. Just wondered if anyone knew if they were interchangeable. Thanks much for any help.
I remember them being identical. I had picked up a replacement for my coupe from a sedan at the junkyard.
yes. it is the same on ALL 92-97 CSs if equipped. iiirc 91-93 GPs could have the same too.
Thanks much for the reply. I'm going to pull both of them at the yard .. and keep other for a spare. Thanks again.
