SrMichi Posted March 16, 2009 Report Posted March 16, 2009 Can anyone please tell me how to change a light bulb on a instument panel on a 94 lumina. after putting in a manual fan switch and re wiring my fog lights i just found out there is a dark spot between my rpm and gas gauge. Quote
5speedz34 Posted March 16, 2009 Report Posted March 16, 2009 Easy. Remove the dash pad. 5 7mm bolts you should be able to see. Remove those push up on the pad and pull it out. Look for more 7mm bolts holding the "lumina" plate on. Then look for the 7mm bolts holding on the cluster. Unplug the harness and pull it out. Go to NAPA and get 194 bulbs but they need to have the base attached to them. You'll see what I'm talking about. The cluster will have a black piece of plastic that needs to be removed from the back to access the bulbs. The bulbs twist out. Quote
5speedz34 Posted March 16, 2009 Report Posted March 16, 2009 That back piece has 7 small torx srwews Ya but I think you can use a regular socket on it too? Quote
AL Posted March 16, 2009 Report Posted March 16, 2009 not 100% sure... I dont remember off the top of my head... Probably a 7mm if it is Quote
SrMichi Posted March 16, 2009 Author Report Posted March 16, 2009 k i got the dash out, the euro sign out and all the bolts on the cluster there is white tube with a retractable wire on the bottom that wont let me pull the thing out. is there a way to take this out or can i just retracted a bit to get enough space to unscrew the black cover? nvm its the shift indicator. i was able to pull it enough and take the black cover out. i took the bulbs out and they where not burned so i took all of them and bent the connectors and put some connector grease. its kinda bright outside but it seems they are all working. later tonight ill be sure Quote
SrMichi Posted March 18, 2009 Author Report Posted March 18, 2009 well they where not all working now the speedometer side does not work i gave it a good smack and it turned on. then today i noticed my right blinker was not working i try smacking it but nothing i had to get a new bulb. now it all works Quote
5speedz34 Posted March 18, 2009 Report Posted March 18, 2009 Good to hear you figured it all out. Quote
