mattlgiberson Posted March 10, 2009 Report Posted March 10, 2009 Ok...I know this has probably been asked a million times before.....but... Will the transmission from a 1994 Cutllass with a 3.1L work in a 1996 with a 3.4L? I gather that the 94 would probably be a 4t60 and the 96 would be a 4t60-E? Quote
Regal_GS_1989 Posted March 10, 2009 Report Posted March 10, 2009 Nope. They are both 4T60E's. With that said, it should work, however there are certain parts that need to be changed around first, though I forget exactly what those parts are. IIRC, the transmissions mounted to the 3.4 also had a different Final Drive ratio than the ones attached to the 3.1, but once again, those parts could be swapped over. Quote
Crazy K Posted March 10, 2009 Report Posted March 10, 2009 i keep hearing that the 96 transmission is 96 only. also, the gear ratio from a 3.4 and 3.1 are different. with an obdII pcm, you will probably have issues. I think Brian P might be able to give you a certain answer on the "unofficial" interchange. Quote
Brian P Posted March 10, 2009 Report Posted March 10, 2009 swap the neutral switch/gear selector switch and there's no other external differences between a '96 tranny and a '94-96 tranny (from a 3100 car). Your only issue would be the gear ratio difference. Even though it's minor, the PCM will pick up on it and raise hell. Quote
