AWeb80 Posted March 8, 2009 Report Posted March 8, 2009 When I Get To Making My Powerlogs next week, do i need to put a bung in for the egr? or can i leave it off? will it set off a ses light if it has no gases going through it? Quote
19Cutlass94 Posted March 8, 2009 Report Posted March 8, 2009 if you dont have an EGR delete in the computer then yes it will throw an SES light. Quote
Pontiac6KSTEAWD Posted March 8, 2009 Report Posted March 8, 2009 That doesnt make sense to me.. If he leaves the EGR system in, and plugs the tube, the computer will think the EGR is there, and working. The computer doesnt measure the amount of gases going thru the EGR, it just measures the amount of open or close on the valve. I dont see any ill affect of leaving the system in if the system is plugged. Quote
95 vert Posted March 8, 2009 Report Posted March 8, 2009 Remember the 3100's with the blocked EGR intake passage causing a check engine light? The EGR opens and the PCM looks for a change from the 02 sensor so it "knows" the EGR is working correctly. Quote
Pontiac6KSTEAWD Posted March 8, 2009 Report Posted March 8, 2009 Was it OBD1 or OBD2? If its OBD2, than maybe I could understand that, but not on OBD1.. I dont remember what year your car was AWEB thou.. Quote
19Cutlass94 Posted March 8, 2009 Report Posted March 8, 2009 his is a 94 or 95. same yr as mine and when the passage is blocked, the PCM does look at the EGR and will give an SES light. Quote
GP1138 Posted March 8, 2009 Report Posted March 8, 2009 Just plugging the sensor in and blocking/removing the tube will not preclude the SES light from coming on. Found this out when I did my 3400 intake swap. Quote
BXX Posted March 8, 2009 Report Posted March 8, 2009 It is needed to keep the light from coming on. Furthermoar, you run a high risk of burning valves without it UNLESS you run a slightly richer fuel mixture. Quote
carkhz316 Posted March 8, 2009 Report Posted March 8, 2009 pontiac6ksteawd said: That doesnt make sense to me.. If he leaves the EGR system in, and plugs the tube, the computer will think the EGR is there, and working. The computer doesnt measure the amount of gases going thru the EGR, it just measures the amount of open or close on the valve. I dont see any ill affect of leaving the system in if the system is plugged. To add/ elaborate on this, as per the error code description, (at least on OBDI cars), under closed throttle decel, the EGR will activate and the ECM will watch for a RPM drop. If it's not detected it will set the EGR code (one of them 30something ones, can't remember) Quote
Brian P Posted March 9, 2009 Report Posted March 9, 2009 carkhz316 said: pontiac6ksteawd said: That doesnt make sense to me.. If he leaves the EGR system in, and plugs the tube, the computer will think the EGR is there, and working. The computer doesnt measure the amount of gases going thru the EGR, it just measures the amount of open or close on the valve. I dont see any ill affect of leaving the system in if the system is plugged. To add/ elaborate on this, as per the error code description, (at least on OBDI cars), under closed throttle decel, the EGR will activate and the ECM will watch for a RPM drop. If it's not detected it will set the EGR code (one of them 30something ones, can't remember) I thought it was looking for a change in the vacuum reading from the MAP sensor? Quote
5speedz34 Posted March 10, 2009 Report Posted March 10, 2009 How does not running a EGR cause a high risk of burning valves? So you guys are saying leave it bolted to the engine and plugged in but with no tube? Quote
xtremerevolution Posted March 10, 2009 Report Posted March 10, 2009 An obd1 car will throw an SES code if the egr isn't working properly, trust me. Quote
BXX Posted March 10, 2009 Report Posted March 10, 2009 5speedz34 said: How does not running a EGR cause a high risk of burning valves? So you guys are saying leave it bolted to the engine and plugged in but with no tube? Higher combustion temps is the main issue. The inert gas through the EGR has a cooling effect. Quote
19Cutlass94 Posted March 10, 2009 Report Posted March 10, 2009 5speedz34 said: How does not running a EGR cause a high risk of burning valves? So you guys are saying leave it bolted to the engine and plugged in but with no tube? With no exhaust gas going to the EGR, it will set off the SES light. Quote
BXX Posted March 10, 2009 Report Posted March 10, 2009 Not to mention fuel trims will be off some.. Quote
5speedz34 Posted March 10, 2009 Report Posted March 10, 2009 Well either way I know you can shut it off via PCM tune. Quote
BXX Posted March 10, 2009 Report Posted March 10, 2009 5speedz34 said: Well either way I know you can shut it off via PCM tune. Yeah. I did on my CS with HPT. I have a blockoff kit from WOT-tech as well. I enrichened the AFR a bit too to keep combustion temps down. Im not a fan of KR Hell, half clogged cat, a decent mild tune and no EGR and my car passed E-check. They had to do a exhaust gas test on the dyno. Passed barely, but it passed.. The guy saw the results, the sticker on my car and said he knew right away I had no EGR Quote
5speedz34 Posted March 11, 2009 Report Posted March 11, 2009 I thought Ohio got rid of emissions testing? Quote
BXX Posted March 11, 2009 Report Posted March 11, 2009 5speedz34 said: I thought Ohio got rid of emissions testing? Not yet they were supposed to but its been prolonged. Its supposed to be up for review again sometime this year I think. But in the end, they wont get rid of it.. Quote
5speedz34 Posted March 11, 2009 Report Posted March 11, 2009 Fucking stupid. Although I should support vehicle emissions, I don't simply because I feel people should be free to do whatever the hell they want to their cars. Unless I can see some serious proof that it helps (or saves) the environment I won't care for it. Quote
Crazy K Posted March 11, 2009 Report Posted March 11, 2009 AWeb80 said: catless smells better anyway. yuck! Quote
