98montels Posted March 6, 2009 Report Posted March 6, 2009 Ok so I tried the search for about 20 minutes and didn't come up with the result I wanted so.....I'm wanting to replace my spark plugs in my 3100, its in a 98 monte LS. Couple questions tho. 1. What brand should I go with (like best quality/ for the price) 2. Would it be best to get double platinum right? I know single platinum is the cheapest type and was told they fowl out sooner and what not. And another thing I noticed is the acdelco double platinum's are pretty expensive compared to say bosch I believe it was. LMK guys I know it's pretty straight forward but I'm just looking for a little input first. Quote
oldscsc Posted March 6, 2009 Report Posted March 6, 2009 Stock Delco's work best...at least I hear. Quote
Regal_GS_1989 Posted March 6, 2009 Report Posted March 6, 2009 Stock AC Delco's. I have used NGK Iridium's in a 3.4 with good success, but you can't go wrong with the stock Delcos. As for platinum, don't bother. There is a chance that it will actually perform worse with the plats. Quote
98montels Posted March 6, 2009 Author Report Posted March 6, 2009 What exactly is a double platinum? I thought it was the electrode was platinum and the deal that the electrode arc's to (forgot what it's called) is platinum too. On a side note about them possibly being worse, a buddy of myn changed his plugs in a jeep 4.0 inline 6. He used oem replacements and all it did was misfire, we even took them out and regaped them. Had to switch to the double platinum and that fixed it. Thanks Quote
98montels Posted March 6, 2009 Author Report Posted March 6, 2009 bump.....anymore info about my last question guys. Getting ready to go pick some plugs up just wanted to know about the platinum deal. thanks Quote
19Cutlass94 Posted March 6, 2009 Report Posted March 6, 2009 In '98 it probably came with regular platnum plugs. Just stick with either AC Delco or NGK. Quote
98montels Posted March 6, 2009 Author Report Posted March 6, 2009 Alright then. So OEM replacements it is then I suppose. I guess the OEM replacement plugs are single platinum I think too. Quote
Night Fury Posted March 6, 2009 Report Posted March 6, 2009 Jeep =/= GM Stock OEM A/C Delco all the way Quote
cutlassdude96 Posted March 6, 2009 Report Posted March 6, 2009 ac raipidfires are another plug you can used Quote
Brian P Posted March 6, 2009 Report Posted March 6, 2009 I've had good feedback using Delcos, and recently I'm running NGK TR55's. Quote
cutty Posted March 6, 2009 Report Posted March 6, 2009 I use regular ac delco's. But i have also seen NGK's that came in a gm box from the parts dept. of the dealer. Quote
