CD player not working
Off of a salvage car at work, I was able to get a 1.5 Gen CD player. It works nice and is in good shape, but the CD player doesn't work. It reads 'err'..
Can these units be rebuilt? It was a free unit so I wouldn't mind putting a little money into it if I could get it fixed.
step 1: remove top cover.
step 2: clean lens. lens cleaner fluid and a q-tip would be nice, but do what you can.
step 3: reinstall cover
step 4: !!!!!
step 5: profit!
step 4: ?????
step 5: profit!
fixed
Great thanks for the info... stand by as I try to tear it apart I may need help.
i dont know much about electronics. hell i dont know anything about them. i have only ever taken apart a ps2 to clean it, but i had spare parts afterwards, but i do know you will have to take more apart that that because the lense is going to be on the bottom of the cp player i hope this helps
look through the hole on the upper left, the small "drilled" hole. the lens is below that. you will need a q-tip.
Okay, I found the lens and cleaned it... Next time I go outside I'll put it in the car and see if it works.
So... you must be agoraphobic. since you haven;t gone outside yet....
Computer's been down... now it skips. I'll keep tinkering with it to see if I can get it right.
