fact/myth questions
1. lower resistance plug wires deliver less spark? heard this from someone but not sure where... had something to do with the secondary ignition being "bass ackwards" in their words. makes no sense to me, can someone explain please.
2. front valance is necessary or else the tranny will die? what all vehicles does it effect and why?
3. no exhaust backpressure will burn exhaust valves? my dad told me this one a long time ago and i really can't figure out why it makes sense if its true. seems like less/no backpressure would allow exhaust to move quicker, transfering less heat to the valve/head/seat.
i'm sure i'll have more as time goes on, but these three stuck out the most
1) Low resistance = more spark
2) Myth, this came about from TGP's have a cooling duct for the tranny cooler beside the valance. A valance not there will not cause your trans to grenade.
3) Not sure, but I've heard less back pressure = more HP but less TQ
x2
Matt speaks what I have always been lead to believe
Jamie
valance: i can't remember who it is but somebody has a lumina with a stock 3.1 and stickers/logos galore on the front and has a valance that was homemade and swore it was necessary
read this and it may answer your question to #3
http://headerdesign.com/extras/design.asp
my brain hurted when i reads that...
seriously though, that hurts to read. just give me an equation and i'll get the right size/length primaries and collector/extension size/length and i'd be happy. thats too much at one time
on to another note: is the jury still in about cai/wai/fwi and their effect on fuel economy? i've seen a properly built ram-air system making like 3psi at 75mph i think and i'm holding off on making my own until i know how bad its gonna drain my wallet at highway speeds. that and i don't know what the pcm would do if it saw anything other than vaccum...
The warmer your engine, the more efficient the combustion cycle is. Hence the reason for WAI's on "hyper-miler" vehicle's. They even run warmer thermostats as well.
3psi, I'd like to see proof of that, with a proper vacuum/boost guage.
THANK YOU!!!!
that may be why i saw 3psi... i don't know what exactly other people do with their cars but i did find it odd, to say the least, that there was positive pressure. i assume you might be able to squeeze a few kPA in, especially with a forward facing TB.
something else: how can about every company on the market claim that CAI save gas? do people actually research these things or does everybody just listen to the manufacturer
in the 80's the trans-am lower valance was required for proper airflow for the cooling of the radiator. there was a TSB about it, when the cars arrived from the plant the air dams were to low to be hauled on the truck so the dealer had to install them at delivery. some didn't and caused strange overheating problems.
i believe i was told this affected the 85 IROC(and others) as well? the bodywork shoved the air up into the radiator, cooling the motor. i was told that after someone saw the hacked to pieces iroc that i had
Did I just get called out in this thread?
yes, sir you did. couldn't remember your name for the life of me
Where's my pop corn....
Jamie
So what words are you putting in my mouth?
http://www.w-body.com/forum/index.php?topic=74622.165
the new site keeps fuckin me up, i can never tell when someone replies to a thread that i did...
i guess that thread got quite a few more responses after i wasn't able to find it anymore.
and i guess i was wrong, you didn't mention it was necessary, sorry about that, my memory has gone to hell and back and i'm not even 20... wow i'm getting old
Its not garden edging, its baseboard molding, the expensive stuff. You remember that. :biggrin:
For the record, its on there to make me laugh every time I see it. Same with all of my appearance mods.
after reading the rest of the wrong wheel thread, i realize it now. hell i didn't even think that thread went on after the last time i posted.
going back to the secondary ignition thing: i've seen ?accel? DIS coilpacks in jegs/summit/etc. would a 3100 recieve any benefit from them? was spark a weaker aspect of the l82 or would there ever be a difference between OEM and aftermarket?
the OEM ignition components are more than adequate.
and yes, the above is a WAI.
thought of something else while i was sleeping:
aluminum vs iron heads: all factors being the same: flow/chamber size/design/etc. does running the same timing on both create equal power and does aluminum allow more advance for the same fuel?
For a Lumina of that era, I don't think any other appearance mod is worth the time. :lol:
another: tuning: wideband only or EGT as well? i think i read that a stoich mixture burns cooler? i have also been told that a wideband can get thrown off due to backpressure. and that spark timing will effect the completeness of combustion
wow... take the time to do some research and try to learn something.
