Seafoaming a 1998 Grand Prix
I have a 1998 Grand Prix GT 3.8L WITHOUT the supercharger and was wondering how to go about seafoaming my car? I have heard to put it through the brake booster line, but where exactly is the brake booster line located at under the hood for my year motor? Is there anyway I could mess up my motor or anything by dumping the seafoam in the brake booster line? Any help is appreciated. Thanks.
Unplug that line with the car running. The line is like 3/4 inch. Pour 1/4-1/2 of can into line slowly taking care not to kill the engine. Then when you're almost done, drown it and let it die.
Let car sit 5-10 mins
Start, DRIVE HEAVILY.
Great, thanks for your help. Is there any way I could possibly mess up my car from using seafoam? Cause I don't want to blow my motor or anything. Also, that picture is hard to tell which line it is. Is that the brake booster line your are pointing to?
Uhh.... pretty much no.
And yea that is the brake booster line... It goes into a dome shaped thing.
So I ended up using the brake booster line on the car but when I took off the brake booster line and started the car up, it didn't rev itself up like it did when I seafoamed my Chevy Cavalier, instead it just puttered and kept seeming like it was going to stall. Once I started pouring the Seafoam in the brake booster line, the motor started revving itself up. I put about half the can in the brake booster line and the other half in the gas tank and then I shut the motor off. After letting it soak for about 30 minutes or so, I started it back up and let it idle for a minute and then started revving it up hoping smoke would pour out since I have never seafoamed my Grand Prix before. I was surprised that only a little bit came out while I was revving it up; no thick smoke at all. Could it be because I dumped the other half of the Seafoam in the gas tank after I put half in the brake booster line? Maybe that has something to do with the amount of smoke coming out. I'm not sure. But regardless it did help get rid of a little hesitation and rough idle/starting of my Grand Prix when it was all said and done.
How many miles does your 98 grand prix have?
My Grand Prix has 166,000 miles on it.
If you could read, I said take it off WHILE RUNNING, but you seem to have done it fine anyways. No smoke means it was already decently clean up in there. Congrats, you have seafoamed a car!
Pour it in slowly. You can lock the motor if you put too much of the stuff in at once.
didn't Irondogg screw up his car by leaving the seafoam in the intake for like a couple hours or so and it clogged up his intake?
Ya, he didn't do it right. i just did the honda, and it smoked for 4 miles. runs great now.
It wasn't Rob, it was someone helping him. I think. But Rob obviously had to fix it. :lol:
No, I was there. I told him to put it in, let it sit for 5 minutes, then start it. He let it sit for 4 hours, then tried starting it. He fouled his fancy spark plugs.
Does it matter where you put the seafoam in.... I have heard let a vaccum line suck it in and DO NOT let the car die... may seem like a dumb question but does it change among cars... and which way is the best??
Last Week, I just poured half the bottle in and then drowned it to kill the motor. let it sit for 5 mins or so. sure, it cranks hard, but the smoke cloud was huge. then went WOT for a few miles and it smoked the whole time. runs great now. ......this was on my civic hatch.
Some people let the vacuum line suck it up, others don't... I get a friend to help me to it. while one of us keeps the idle up so the car doesn't die, the other dumps the whole bottle in a funnel that is in the end of a vacuum line, once the bottle is empty you let the engine die
let it sit for a few minutes then go for a drive, then change your oil.
According to the bottle, you can also add it to your fuel to clean the fuel system, and add it to the crank case to clean out sludge.
Last time I seafoamed my car I did all 3 methods, added some to the gas, once I was down to half a tank I added it to the crank case, then after about 300km I put it in the vacuum line. Then I changed the oil, letting it drip out all afternoon just to be safe. Installed my filter and filled with oil...
I'm sure someone is going to say that's overkill, but I don't care, lol
Jamie
pour it slowly into the brake booster vacuum line. its the biggest vac line usually.
I tried doing it to my 00 Jimmy and when I re-started it after the whole thing, it didn't smoked at all, why would this hapenned?? it was a while ago and it seems to be okay :dunno:
