AL Posted February 23, 2009 Report Posted February 23, 2009 One of my buddies has a 3100 96 GP that was throwing a EVAP no flow code... So I brought it into the shop and cleaned dirt out of the vacuum lines... Well the code came back but now it says there is inaccurate flow... I dunno what to check next unless there is dirt in the purge soleniod... We tested the solenoid and it works great. Also, he has a random plug around the back of the motor that is unplugged and I dont know what it plugs into, there are two wires coming from it. Quote
slick Posted February 23, 2009 Report Posted February 23, 2009 Take a picture of the plug. EVAP could be a few different these. Make sure the EVAP lines are not broken, cracked, etc... Quote
BXX Posted February 23, 2009 Report Posted February 23, 2009 the plug back there is just an extra it doent go anyehere. check the vacuum lines back there on the purge solenoid. its known to crack and leak. you will have to remove it from there rear to get a better look Quote
AL Posted February 23, 2009 Author Report Posted February 23, 2009 Ok all the vacuum lines are in good condition... But I removed the solenoid and switch only to find a ton of dirt... So I cleaned it out and it should be good. Quote
