92 Grand Prix lock cylinders
Hey all, I have a quick question. It seems that the cylinders won't turn at all, i put the key in and they only jiggle a little, nothing close to an unlock, I noticed that it happened after someone tried to put the key in upside down and i couldn't find a connection
try spray wanding wd40 or pbblaster int eh lock. otherwise, your lock may simply be broken beyond repair.
did the wd40, on both sides it worked fine then locked up right after someone put a key in upside down and tried to unlock it, would that really lock it up? and break it?
They probably fucked up the tumblers inside the lock doing that.
so is it fubared?
The GP locks/handles are notoriously fragile and break easily. Looks like you'll be needing a new one.
