Cutlass column interchange
Has anyone successfully put a 94 steering column in a 93 cutlass. I have a 93 that I am switching over to a 94 dash that is gray. I want to use the 94 column cause it fits the new dash pieces. Anyways the plugs are the same but the amount of wires are different. The 93 column has more wires hooked to the switch. Does anybody have the wiring diagram for the 93 and 94?
I dont know about the 93 but on the 92 column the bolt hole centers are larger then the 94 so you might have to change the white metal casting also which is no easy task ( re 5 spd vert swap)
