How Much Oil Does Your Car Burn?
  • Replies 58
  • Created
  • Last Reply
Top Posters In This Topic
  • mfewtrail
    4
  • Addicted To Boost
    4
  • Night Fury
    4
  • slick
    3
Hopefully, none now that the LIM gasket is repaired. It really didn't seem to leaking much before it was fixed either. But when the plenum gasket went, that was really something!
Zero. Nada. Zilch. 000. None. 100-100. -23+23. NOTHING. WEWT!
I fucking love this car.
My 6000 on the other hand.... Never even needed an oil change between the burning and the leaking.
Zero on both of my GPs... However the TGP belched a quart or two of trans fluid onto the garage floor while I was gone :lol: Time for a new trans pan gasket!
I'm lucky enough to have a car that doesn't leak or burn a drop of oil. The only thing it leaks is just a tad bit of coolant, just a few drops per week.
Mine leaks just a wee bit of trans fluid. But I'll have that fixed.
half quart every 1000 miles
mine only burns this much because ive been driving it harder since gas is still low
I don't think it burns or leaks any now. It drips a bit of everything when it gets -30c, but now it doesn't.
Zero on the Regal (before it blew up, after the engine rebuild)
TGP probably leaks like a sieve/burns like a BBQ.
Euro doesn't burn any.
1/4 a quart every 4,000 miles. I suppose that's what one would come to expect with a 194,000 mile abused GM vehicle.
My cars don't leak nor burn any discernable amount of oil at all. The oil levels always stay full during my oil change intervals. I fix any leaks as soon as I come across them, so my cars rarely have leaks.
Sure it's the trans pan gasket? They usually don't leak other than a small drip when the bolts are loose. The stock reuseable gasket(assuming it's still on your car) rarely break or leak.
Every 3,000 when I change my oil, I'm about half a quart less than what I put in. I assume some of it is in the filter, and the rest is burned off.
None, and if you are leaking oil then fix the leak. Having a puddle under your parked car is not cool. :willynilly:
half a litre between changes on the Cutty. None on the TGP. Have only done one oil change on the Fiero so far so I dunno on that one.
half a litre every month on the GTP, half a litre every fill up on the 3rd Gen Camaro... (huge leak needs fixing)
almost 3 quarts every 3000 miles. leaked that much before and after re sealing the motor and replacing the bearings, although the motor has over 200k on it and the cylinder walls still have the crosshatch mark on them.
