mfewtrail Posted February 11, 2009 Report Posted February 11, 2009 I figure why replace the fuel pump if its not broken? OEM is probably better quality than most aftermarket ones anyways. Only has 48k miles on it, and isn't noisy. I wouldn't have changed it with that low of mileage either. The original pump on my '93 died @ 245,000 miles. Those fram fuel filters are fine to use. I've used several in the past. They filter a bit less, but flow more than most other filters available for our cars. Unless you have leaks in the tank or fill up at somewhere super shitty, you don't have to worry a lot about filtration. At 245K miles, my gas tank didn't have so much as a speck of dirt/sediment in it. Quote
