White93z34 Posted February 10, 2009 Report Posted February 10, 2009 Yeah the tank I got came from Advance Auto. The pump is a Bosch. I love those pumps and will swear by them. The sender I got off rock auto, "spectra premium" IIRC. It works, but not in the same fashion as the OE ones. this one will fall off full fast but hang at empty forever. I replaced the tank because when the car sat for several years with nasty gas in it it rusted the inside of the tank and was contaminating the gasoline. oddly enough I gave the tank to some kid who put it in his shitbox base lumina after he ran over a jack stand and punctured his tank Quote
GOT2B GM Posted February 10, 2009 Author Report Posted February 10, 2009 one thing to check on the new tank. make sure at the big end of the tank that is closest to the monoleaf that the edges of the tank are bent up like the OE tanks are. I forgot to check that on the new tank I got for the Euro and that made installation a pain in the ass when the tank straps got hung up there. good to know. The tank is a Spectra Premium. Made in Canada FTW Quote
Captain Ficho Posted February 10, 2009 Report Posted February 10, 2009 If I remember correctly, when I saw/owned that tank it had the bent up corners so you should be fine. Canadian made products ftw, Quebec made products... not so much but still ftw. Quote
White93z34 Posted February 10, 2009 Report Posted February 10, 2009 one thing to check on the new tank. make sure at the big end of the tank that is closest to the monoleaf that the edges of the tank are bent up like the OE tanks are. I forgot to check that on the new tank I got for the Euro and that made installation a pain in the ass when the tank straps got hung up there. good to know. The tank is a Spectra Premium. Made in Canada FTW I forgot to mention, my tank is a spectra premium as well! Quote
CSI_MuNkY Posted February 10, 2009 Report Posted February 10, 2009 The house smells like gas! All I could smell when I got home from school... its all good now though! Jamie Quote
GOT2B GM Posted February 11, 2009 Author Report Posted February 11, 2009 Now my exhaust makes the underside look like ass, but the rest looks pretty good for a northern car. Quote
5speedz34 Posted February 11, 2009 Report Posted February 11, 2009 At first I thought it was plastic, then I forgot you undercoated it. So did the pump go or is this just preventative maintenance.? Quote
GOT2B GM Posted February 11, 2009 Author Report Posted February 11, 2009 The tank was leaking above 1/2. Bought this brand new one off of Filip (Captain Ficho) He didn't end up needing it for his car (leaking filler neck) This car only has 48,xxx miles so I reused the original pump. Sending unit was good too, hardly any rust at all. Quote
5speedz34 Posted February 11, 2009 Report Posted February 11, 2009 I wonder if you can get aftermarket filler necks for these since they like to rust. Quote
5speedz34 Posted February 11, 2009 Report Posted February 11, 2009 Gotcha....shitty to because isn't it a common part to go bad? Quote
Addicted To Boost Posted February 11, 2009 Report Posted February 11, 2009 I spy a Fram fuel filter! Quote
5speedz34 Posted February 11, 2009 Report Posted February 11, 2009 Please let's not start that debate again. Quote
White93z34 Posted February 11, 2009 Report Posted February 11, 2009 Anyone who brings up that shitstorm in this thread will get a vacation. Quote
5speedz34 Posted February 11, 2009 Report Posted February 11, 2009 Anyone who brings up that shitstorm in this thread will get a vacation. LMFAO!!! Serious? Quote
GOT2B GM Posted February 11, 2009 Author Report Posted February 11, 2009 Had it on my shelf. It filters fuel. Quote
GOT2B GM Posted February 11, 2009 Author Report Posted February 11, 2009 Gotcha....shitty to because isn't it a common part to go bad? In the rustbelt yes Quote
5speedz34 Posted February 11, 2009 Report Posted February 11, 2009 Gotcha....shitty to because isn't it a common part to go bad? In the rustbelt yes Comon' doesn't that go without saying...no I expected this to be a common rust issue in Florida. LOL. Quote
AL Posted February 11, 2009 Report Posted February 11, 2009 I got a filler neck from GM for 75 dollars and Breakdown bought it off my parts car 4k miles later. Quote
GOT2B GM Posted February 11, 2009 Author Report Posted February 11, 2009 What my car really could use is the pair of steel lines running from the EVAP can to the top of the rear subframe. Mine are very crusty. Quote
5speedz34 Posted February 11, 2009 Report Posted February 11, 2009 Ya I don't think those got touched at all from the factory. Quote
89GP_SE Posted February 11, 2009 Report Posted February 11, 2009 i dont know why ppl complain so much about doing fuel pumps, I did mine outside in minus 40 in the snow on drive on wheel ramps, only took me 2 hours, and I live in crappy climate as well. if that were me though, I would have replaced the fuel pump with the new tank aswell, might as well since you had it down and all. Oh well to each their own. Quote
digitaloutsider Posted February 11, 2009 Report Posted February 11, 2009 Anyone who brings up that shitstorm in this thread will get a vacation. FRAM arguments are only allowed when we're talking about oil filters! Quote
GOT2B GM Posted February 11, 2009 Author Report Posted February 11, 2009 I figure why replace the fuel pump if its not broken? OEM is probably better quality than most aftermarket ones anyways. Only has 48k miles on it, and isn't noisy. Quote
