100k maintenance on 03 GP 3800
I am only at 84k miles but I wanna start picking up parts for my 100k maintenance... So far my list includes:
Struts/Mounts
Brake fluid flush
Coolant flush
Trans fluid/Filter
Lower intake gaskets
Upper intake gaskets
Spark Plugs/Wires
PCV valve
Fuel Filter
Any others I should add? Whats known for failing/needing replaced?
replace the upper intake itself with the improved one. this is the biggie for the L36.
inspect brakes.
install a cabin air filter since the GP's didnt come with one. just ask for one for a regal. the provisions are there, just no air filter. it goes under the cowl. when doing this make sure the weatherstripping that blocks water from entering the cabin air box is attached well.
clean the EGR.
clean the MAF with MAF ONLY cleaner.
clean the throttle body.
replace serpentine belt.
Better one as in the L26 one?
inspect brakes.
I dont think I have heard of that before... Where exactly is that filter box at?
clean the EGR.
My replies are in bold
inspect brakes.
clean the EGR.
The L26 one will not work, I don't think. Since it uses the drive-by-wire TB, I'm pretty sure the L36 TB won't bolt up. They have an improved/reinforced L36 upper intake that won't warp like the factory ones will. ZZP sells it, and other places do too. My mechanic got one for me a while back.
To do the cabin air filter/weatherstripping under the cowl, this is a great help!!
http://www.clubgp.com/newforum/tm.asp?m=2398123&p=1&tmode=1&smode=1
No, it's a better designed, for the L36's. IIRC, it puts a metal pipe inside the EGR passage.
Wow, I didnt even think of Seafoam... I think I am going to add HUD and a DIC to it also...
Heres my final list I think
Struts/Mounts
Brake fluid flush
Coolant flush
Trans fluid/Filter
Add improved upper intake
Spark Plugs/Wires
PCV valve
Fuel Filter
Cabin Air Filter
Clean EGR
Clean Throttle Body
Clean MAF with MAF only cleaner
Serpentine belt?
Seafoam
Heater core hoses
Thermostat
Radiator Hoses?
Those aren't 100k mile fixes!LOL.
Everything posted thus far is pretty much what I would do at 100k. Remember mileage is only a number haha.
Oil change will be done at whatever 3k interval is around it... Which will be (86, 89, 92, 95) 98k and 101k
You need to be sure to change the oil as soon as you swap the intake gaskets, then again another 500 miles later.
Coolant WILL drop into the oil when your changing the stuff. So, as soon as you do the gaskets, and before you fire it up, change the oil. Don't use anything too nice, because about 500 miles later, once you get some miles on it to flush out the coolant, change it again. Will keep you from potentially ruining the engine.
Wow, didnt know that... The intae gaskets are what the 3800 is known for blowing right
Big time and if its for any prolonged period it will kill the motor.
I will do the coolant flush right before I do this then so I wont have any coolant in there, then when I am done I can fill it with coolant
Ok so I have been looking up parts and prices... Keep in mind that this car is a daily driver and I drive it kind of hard, but not looking to mod it or race it, but a little step-up from here to there is fine with me.
What are the best spark plugs for stock, or a step-up from stock performance and reliability?
I was looking at these but 7 bucks a spark plug seems high (hope the links work)
http://shop.advanceautoparts.com/productdetail.aspx?MfrCode=ACD&MfrPartNumber=41101&PartType=960&PTSet=A
I have also heard many good things about Autolite plugs/wires, Are they better than Delco? Any more info I can get on them would be greatly appreciated
Struts, Monroe Sensa-Trac seem decent... Im not looking to lower or for major handling increases, just looking for a comfortable ride. Any experience with those? Are there better ones in the same price range?
Fuel Filter, I plan on picking up ZZPs high flow filter... Good idea, Bad idea?
I will also pick up the cabin air filter from the regal and install that, and clean the MAF in the next couple of days.
Struts/Mounts
Brake fluid flush
Coolant flush
Trans fluid/Filter
Spark Plugs/Wires
PCV valve
Fuel Filter
I started to make a response that struts and mounts should be good till 160,000km minimum and then I thought 100K miles = 160K kilometers.
Still, they shouldn't go right away then either.
That would be a minimum.
Thanks for the info on the cabin filter Independentfool, I was getting my oil changed when the guy told me "You have no cabin air filter." And since the previous owners did good maintenance on just about everything else I was like WTF!!!
That explains it. Now I have a charcol filter.
The struts I dont NEED... In fact, I wont even get them till probably 98k or 100k miles... But I wanted to look and get opinions ahead of time... I figure with the car being a rental, It could probably use them, and I just want a better ride... The ride now is fine but it could be smoother.
I think that I'm aboot 15K short of you, my struts are stiff as hell still, as in not showing signs of wear - at least in my opinion.
