meltboy1 Posted February 7, 2009 Report Posted February 7, 2009 I am starting the removal of my tranny in the 89 5spd to replace the throwout bearing, and I need to remove the clutch master cylinder pushrod clip, how in the hell do I do that, I can't even begin to imagine how to get anything up in there to remove it, there is absolutely no room. Is there something else under the dash I can take off easily to access that? Quote
White93z34 Posted February 7, 2009 Report Posted February 7, 2009 why in the world do you have to remove the master cyl from the car to do a TO bearing? just unbolt the slave cyl from the trans and move it up out of the way. also, only way to get that clip out is to break it, it is a one way street. Quote
meltboy1 Posted February 7, 2009 Author Report Posted February 7, 2009 idk the book said i had to remove that clip to get the tranny out, i have never removed a standard tranny from a car before so i was just goin by the book. Quote
White93z34 Posted February 7, 2009 Report Posted February 7, 2009 how are you removing the trans? top or bottom? if you are going out the bottom i would just move the slave cyl up and out of the way, just DO NOT push the clutch pedal while it is like that. If you want i can dig up the part number for that clip, according to my manual, and what i found in practice the clip is not reusable. I think I paid about $6 for the little thing at the dealer. Quote
meltboy1 Posted February 7, 2009 Author Report Posted February 7, 2009 ya i am coming out of the bottom, I don't have access to a cherry picker... ok I will go that route then, I thought it was kinda odd it told me to remove that, it didn't seem necessary Quote
5speedz34 Posted February 7, 2009 Report Posted February 7, 2009 Where is this clip that you speak of? I totally agree with Chris though, you shouldn't have remove any of that stuff. Quote
meltboy1 Posted February 7, 2009 Author Report Posted February 7, 2009 on the top of the clutch pedal inside the car Quote
White93z34 Posted February 7, 2009 Report Posted February 7, 2009 The clip is at the top of the clutch pedal. It holds the clutch master cyl to the pedal itself. Quote
5speedz34 Posted February 7, 2009 Report Posted February 7, 2009 Is it like a round clip with slots in it? Almost looks like a little plastic cog? Quote
meltboy1 Posted February 7, 2009 Author Report Posted February 7, 2009 Well I hit my stopping point for today, gona wait til I can get another pair of hands on it. So far, I disconnected the shifer linkage, SMC, wiring attached, drivers side tie-rod end and ball joint off, axle out of that side, axle loose on passenger side, but not out yet, drained the fluid. I currently have the jack and 2 jackstands on the front of the subframe, and a tire under each side of the car, so it aint fallin. Any tips for the rest of the tranny removal Quote
meltboy1 Posted February 7, 2009 Author Report Posted February 7, 2009 ya, that's not an issue anymore, but ya, that's about what it looks like. Quote
5speedz34 Posted February 7, 2009 Report Posted February 7, 2009 So are you dropping the whole cradle or just the drivers side? Quote
meltboy1 Posted February 7, 2009 Author Report Posted February 7, 2009 well I've read it's possible without dropping the cradle at all, but if I have to drop it at all I plan to drop only the drivers side. I really don't see how it is possible to pull it without dropping the cradle at all though... Quote
meltboy1 Posted February 14, 2009 Author Report Posted February 14, 2009 Would this be a decent choice for me? http://shop.advanceautoparts.com/ProductDetail.aspx?MfrCode=PHT&MfrPartNumber=MU591A&PartType=244&PTSet=A By Release bearing, is that the same as the throwout bearing, is that also refered to as clutch release bearing? Quote
White93z34 Posted February 14, 2009 Report Posted February 14, 2009 FUCK perfection clutches. Seriously. I have one in my z34 right now. It is good for about one WOT run. then it is awful for hours afterwards. I would never put another back in my car. Quote
meltboy1 Posted February 14, 2009 Author Report Posted February 14, 2009 ok, they suck, got it... then who do I wana go with... lol I would like to just get the kit with everything but I don't know what brands are good, can you provide a suggestion? Quote
White93z34 Posted February 14, 2009 Report Posted February 14, 2009 Thats a good question, honestly. I've been shopping around a little myself. Hopefully someone that knows their clutches will chime in soon. I know a GM clutch disk runs under $200. I haven't got as far as asking about a complete set yet. Spec is supposed to make some nice clutches as well. Quote
