What to do (poll)
Which should I do about the 5 speed (read first post before voting, please)
  1. 1. Which should I do about the 5 speed (read first post before voting, please)
    • Fix the motor problems
    • Swap the motor out
Heres my issue... I am debating which I should do... In either case, I will be replacing the clutch.
Car/issue in question:
http://www.w-body.com/forum/index.php?topic=71173.msg1010842#msg1010842
Option 1 details: The car needs a new alternator... But I dont know what else it might need further down the road... I know nothing about the history of the motor thats in it because its not the original motor... The PO bought the motor trans combo from a junkyard 92 Lumina z34... He couldnt get it running right so he sold it to me... He put a new timing belt on it and it is timed correctly... I have replaced the plugs, wires, battery, MAP sensor, fuel filter, pcv valve, serpentine belt and a couple other things, but I think it has a stuck lifter or something cause something is just not right about it.
Option 2 details: I have a 93 GP SE parts car with a great running LQ1 and a perfect automatic trans... I could pull the motor out, sell the trans, and drop it in the 5 speed along with the new clutch... Before I bought the 93, I talked to the owner for an hour and learned most of the history of the car... I bought it off the original owner and have all the maintenance records of the car and engine... The oil pump drive seal leak was fixed and it cost him $600.
I would like opinions please, and thank you.
swap the motor out. It would be a perfect spring project and at least you know the history
I could probably rebuild the one that is in it now and have a back up for later... Hmmm... Time to find a rebuild kit...
Anyone wanna play devils advocate
I'm all for fixing the problem. It would suck if you swapped the motor, and you have the same problem occuring :lol:
Actually... I could swap the motor... And put the new parts from the one thats in it now and have an even better running LQ1...
series 2 supercharged, 6 spd out of a G6, and heated and cooled seats out of a Caddy.
Oh wait that's what I want :lol: :lol:
I say fix it unless you are absolutely certain the motor you would be swapping was in good condition.
I concur unless you were having any other problems with it.
