lb79theone Posted February 4, 2009 Report Share Posted February 4, 2009 I did not want to make two seperate threads for these questions so here they arre. 1.) I have a 1997 LS Monte, what engine oil do you recommend for this car/ the best engine oil out there? 2.) Should I run a resonator in my exhaust? http://www.wbodystore.com/grandprix/resonators-25-30-p-196.html ^ this one good? Here is a video of my exhaust, not that good but I want a lower growl and not necessaraly quiter exhaust though. What do you guys think? Thank you in advane! Quote Link to comment Share on other sites More sharing options...
lb79theone Posted February 4, 2009 Author Report Share Posted February 4, 2009 Are* and advance* and the car has 80,000 miles on her. Quote Link to comment Share on other sites More sharing options...
jake91 Posted February 4, 2009 Report Share Posted February 4, 2009 i like valvoline 5w30 and yes run a resonator Quote Link to comment Share on other sites More sharing options...
88red4cyl Posted February 4, 2009 Report Share Posted February 4, 2009 In my 3100 Lumina, I run Castrol GTX 10w30... Mine has almost 150k miles on it though, so I don't feel comftorable running that thin of an oil in it... I don't see any problem with 5w30 in yours though since you have a lot less miles than I do... I use Valvoline in my LTZ, just because that is what oil the previous owner used, so that is what I stuck with.. I've always heard that it is best to stick with the same kind of oil if at all possible, but I don't know if there is any truth to that... Quote Link to comment Share on other sites More sharing options...
Addicted To Boost Posted February 4, 2009 Report Share Posted February 4, 2009 The oil topic has been discussed and beaten to death many times. Use the search function and you will find several oil threads. Quote Link to comment Share on other sites More sharing options...
jake91 Posted February 4, 2009 Report Share Posted February 4, 2009 In my 3100 Lumina, I run Castrol GTX 10w30... Mine has almost 150k miles on it though, so I don't feel comftorable running that thin of an oil in it... I don't see any problem with 5w30 in yours though since you have a lot less miles than I do... I use Valvoline in my LTZ, just because that is what oil the previous owner used, so that is what I stuck with.. I've always heard that it is best to stick with the same kind of oil if at all possible, but I don't know if there is any truth to that... i use 10w30 i only suggested 5w30 because he lives in a cold climate and i have heard that about switching oil also Quote Link to comment Share on other sites More sharing options...
ns87 Posted February 4, 2009 Report Share Posted February 4, 2009 If the engine has been properly cared for in its lifetime, then the type of oil you use doesn't really matter. Just keep changing it on time. In my opinion anyway Quote Link to comment Share on other sites More sharing options...
lb79theone Posted February 4, 2009 Author Report Share Posted February 4, 2009 Ok, thanks guys. Quote Link to comment Share on other sites More sharing options...
lb79theone Posted February 4, 2009 Author Report Share Posted February 4, 2009 I have been doing some research and I think I am going to switch to Amsoil and a K&N Oil filter... and what will a resonator do to the sound? Make it quiter or? AMSOIL!! best synthetic out there!???!!!???? Resonator? still loud but less raspy?? Quote Link to comment Share on other sites More sharing options...
Addicted To Boost Posted February 4, 2009 Report Share Posted February 4, 2009 Amsoil is a very good oil, but it is also very spendy. I wouldn't waste money on putting expensive oils in a 3100, when it will probably run the same with any other oil imo. Same thing with oil filters, just run an AC Delco or WIX oil filter, they work very well and are inexpensive. Quote Link to comment Share on other sites More sharing options...
Andrew Posted February 4, 2009 Report Share Posted February 4, 2009 K&N oil filters are terrible!! stick with what nick said. and i agree, dont bother with synthetic oil on the 3100. Quote Link to comment Share on other sites More sharing options...
Addicted To Boost Posted February 4, 2009 Report Share Posted February 4, 2009 If you must run a synthetic, the Supertech oil WalMart carries is actually a good oil.. and its inexpensive. I'm running it in my 91 GP right now, along with an AC Delco PF52. Quote Link to comment Share on other sites More sharing options...
Night Fury Posted February 4, 2009 Report Share Posted February 4, 2009 That's what I'm using next change Nick! I need low profile ramps though! Quote Link to comment Share on other sites More sharing options...
Addicted To Boost Posted February 4, 2009 Report Share Posted February 4, 2009 Pfft just lay cardboard on the ground and weasel your way under there. Seriously though, if I can get under my GPs with intact lower valences, you can do yours Quote Link to comment Share on other sites More sharing options...
Night Fury Posted February 4, 2009 Report Share Posted February 4, 2009 Good Idea! I guess I just didn't really think of that since the weather has been so SHITTY there was no way for ground touching!! Quote Link to comment Share on other sites More sharing options...
Addicted To Boost Posted February 4, 2009 Report Share Posted February 4, 2009 cardboard on the ground Re-emphasized, just for you Buck. <3 Quote Link to comment Share on other sites More sharing options...
Night Fury Posted February 4, 2009 Report Share Posted February 4, 2009 I gotcha! Jeez! but the cardboard would get soggy if there was SNOW on the ground! <3 Quote Link to comment Share on other sites More sharing options...
Addicted To Boost Posted February 4, 2009 Report Share Posted February 4, 2009 Layer the cardboard then Then the one on top won't get wet! Quote Link to comment Share on other sites More sharing options...
Night Fury Posted February 4, 2009 Report Share Posted February 4, 2009 Cardboard is in short supply around here! Don't worry, I'll use cardboard. I won't waste money on ramps. And I'll think of you while I'm under there getting all hot and oily and flustered! Quote Link to comment Share on other sites More sharing options...
Addicted To Boost Posted February 4, 2009 Report Share Posted February 4, 2009 Oh good lord lol Quote Link to comment Share on other sites More sharing options...
Night Fury Posted February 4, 2009 Report Share Posted February 4, 2009 Quote Link to comment Share on other sites More sharing options...
jake91 Posted February 4, 2009 Report Share Posted February 4, 2009 That's what I'm using next change Nick! I need low profile ramps though! buy those plastic looking rhino ramps they are 35 dollers at autozone i have them and they are great the even fit under my moms grand am Quote Link to comment Share on other sites More sharing options...
w-bodys_are_the_best Posted February 4, 2009 Report Share Posted February 4, 2009 I use my floor jack most of the time, and put a small jackstand (wood blocks work too) under the subframe and lower the jack until it starts touching the stand, though I leave 90% of the weight on the jack, I use the jackstand just in case. You don't get a second chance when your melon is under the subframe and over 1,000 lbs. Ramps are easier, but most w-bodies botom out on them before the tire is close. My Z24, and van work fine on them and the Buick scrapes, but makes it up. I've had a nice jack and set of stands, but last summer my mom found some metal ramps for 50 cents at a rummage sale and gave them to me they work great. Quote Link to comment Share on other sites More sharing options...
GOT2B GM Posted February 4, 2009 Report Share Posted February 4, 2009 whatever synthetic is on sale, and yes on the resonator. AC delco or Napa gold filters although it seems they've both been cheapened up recently. Just roll a floor jack under the subframe and take some weight off the suspension (not taking the wheels off the ground) when doing an oil change, makes it easier to get under there. Just back it up with a jackstand for safety. Quote Link to comment Share on other sites More sharing options...
GOT2B GM Posted February 4, 2009 Report Share Posted February 4, 2009 Normally I just use my Rhino ramps, but the TGP is too low, thats where my 2.5 ton aluminum low profile jack comes into play (only 1.5" from floor to top of jack pad) Quote Link to comment Share on other sites More sharing options...
