88red4cyl Posted January 30, 2009 Report Posted January 30, 2009 Like the title says, my 95 Lumina won't turn over... When I turn the key, I get a click from the engine bay... I charged the battery, so that is not it... Fuses looked good as well... Where should I go now? Quote
ManicMechanic Posted January 30, 2009 Report Posted January 30, 2009 Smack the starter with a hammer. You might be able to get it started that way. Check your aux. post. Sounds like your solenoid went. Quote
pwmin Posted January 30, 2009 Report Posted January 30, 2009 agreed...have someone tap the starter. you may need to jump it, too. try wiggling the battery cables, too Quote
88red4cyl Posted January 30, 2009 Author Report Posted January 30, 2009 Smack the starter with a hammer. You might be able to get it started that way. Check your aux. post. Sounds like your solenoid went. Dumb question, but where is the started located at exactly? Reason I ask is because we have a few inches of snow on the ground, and I was wondering if it was possible to get to without laying down... The car has done this periodically since i got it... Usually if you let it sit for 5 or 10 minutes, it would start right up and not have any more problems for months... But it has been doing it more and more frequently lately, and this time it won't start at all... Quote
88red4cyl Posted January 30, 2009 Author Report Posted January 30, 2009 agreed...have someone tap the starter. you may need to jump it' date=' too. try wiggling the battery cables, too [/quote'] well, I'm by myself this morning, and no one would be available to help me until after dark... Would my battery charger work for jumping it? Quote
ManicMechanic Posted January 30, 2009 Report Posted January 30, 2009 Smack the starter with a hammer. You might be able to get it started that way. Check your aux. post. Sounds like your solenoid went. Dumb question, but where is the started located at exactly? Reason I ask is because we have a few inches of snow on the ground, and I was wondering if it was possible to get to without laying down... The car has done this periodically since i got it... Usually if you let it sit for 5 or 10 minutes, it would start right up and not have any more problems for months... But it has been doing it more and more frequently lately, and this time it won't start at all... You will have to lay down...Just above the subframe... Me, I can replace the starter without jacking up the car...LOL! Not many people can do that. THis is my van, but the same basic layout. Round cylindrical with a bunch of wires sprouting out of it. Quote
88red4cyl Posted January 30, 2009 Author Report Posted January 30, 2009 So it is on the front of the motor? And just hit it with a hammer? I went to try and start it again, and it isn't even clicking now... Quote
89SupremeCutty Posted January 30, 2009 Report Posted January 30, 2009 So it is on the front of the motor? And just hit it with a hammer? I went to try and start it again, and it isn't even clicking now... sounds like a bad battery. Quote
88red4cyl Posted January 30, 2009 Author Report Posted January 30, 2009 So it is on the front of the motor? And just hit it with a hammer? I went to try and start it again, and it isn't even clicking now... sounds like a bad battery. I hooked my charger up to it, and it said it was charged... 12.6 volts or something like that... EDIT--- Hm... Put the charger back on it for a while, and now it is showing 14.7 volts... Quote
TIE1-ON Posted January 30, 2009 Report Posted January 30, 2009 Even a charged battery doesn't mean it's "good". I say it's your battery. Change it. Quote
88red4cyl Posted January 30, 2009 Author Report Posted January 30, 2009 Even a charged battery doesn't mean it's "good". I say it's your battery. Change it. Hm.. If that's true, then how come sometimes it will start the car, and sometimes it won't? Everything in the car seems to be working when I turn the key as well.. The lights are all bright, etc... Quote
TIE1-ON Posted January 30, 2009 Report Posted January 30, 2009 Even a charged battery doesn't mean it's "good". I say it's your battery. Change it. Hm.. If that's true, then how come sometimes it will start the car, and sometimes it won't? Everything in the car seems to be working when I turn the key as well.. The lights are all bright, etc... The battery is under much more load when trying to start it then for powering lights, radio, etc. The intermittent problem you state sounds like a cell (or cells) are going bad. Quote
88red4cyl Posted January 30, 2009 Author Report Posted January 30, 2009 Thanks for all the help guys! I left the charger connected for 45 minutes, and then started it with the charger still connected... Fired it right up.. I'm going to swing by a parts store in a few minutes and get the battery checked out by one of their machines... I suppose the starter could still be bad too though, and I just got lucky? I never did hit on it... Quote
88red4cyl Posted January 30, 2009 Author Report Posted January 30, 2009 Well, I changed the battery, and the car starts now... Only problem is, that it cranks really slowly... Would that be a bad starter/solenoid? Quote
ManicMechanic Posted January 30, 2009 Report Posted January 30, 2009 Well, I changed the battery, and the car starts now... Only problem is, that it cranks really slowly... Would that be a bad starter/solenoid? Most likely...MY CS would turn over real slow or just not turn over at all. Starter went bad. Quote
88red4cyl Posted January 30, 2009 Author Report Posted January 30, 2009 Well, I changed the battery, and the car starts now... Only problem is, that it cranks really slowly... Would that be a bad starter/solenoid? Most likely...MY CS would turn over real slow or just not turn over at all. Starter went bad. Which would it be? And if I go to AutoZone and buy a starter, does a new solenoid come with it? Quote
pwmin Posted January 30, 2009 Report Posted January 30, 2009 Well, I changed the battery, and the car starts now... Only problem is, that it cranks really slowly... Would that be a bad starter/solenoid? Most likely...MY CS would turn over real slow or just not turn over at all. Starter went bad. Which would it be? And if I go to AutoZone and buy a starter, does a new solenoid come with it? yes, it comes w/ a new sol. Sounds like you got lucky that it started. Quote
88red4cyl Posted January 30, 2009 Author Report Posted January 30, 2009 Well' date=' I changed the battery, and the car starts now... Only problem is, that it cranks really slowly... Would that be a bad starter/solenoid? [/quote'] Most likely...MY CS would turn over real slow or just not turn over at all. Starter went bad. Which would it be? And if I go to AutoZone and buy a starter, does a new solenoid come with it? yes, it comes w/ a new sol. Sounds like you got lucky that it started. Its turned over every time I have started it since I got the new battery.. The one I took out of it was an Interstate from October 2000... I was really surprised that it lasted that long... Quote
