lb79theone Posted January 30, 2009 Report Posted January 30, 2009 I have a situation! I have that ram air intakes on my LS and I am having a problem with the threads of the hose clamps keep backing ou due to vibration! I put automotive goop on the threads and it helped but it is such s mess! Does anyone have a solution to this problem I am having? Thanks in advance! Brendon from Maine. Quote
lb79theone Posted January 30, 2009 Author Report Posted January 30, 2009 These were brand new when they did it, thats what sux! Quote
TIE1-ON Posted February 1, 2009 Report Posted February 1, 2009 I'm guessing you tightened these hose clamps down a few times and each time you put a little more torque on them and that might be the problem. Over torqued hose clamps will fail and not hold. Quote
rockfangd Posted February 1, 2009 Report Posted February 1, 2009 I'm guessing you tightened these hose clamps down a few times and each time you put a little more torque on them and that might be the problem. Over torqued hose clamps will fail and not hold. x2 tighten till it is tight but a little too far is too late Quote
lb79theone Posted February 1, 2009 Author Report Posted February 1, 2009 AHH, ok. Makes sense, thanks! Quote
