drivers information center
will a drivers information center out of an earlier cutlass work in a 1994
There's a lot of things to hook up to it and DIS's are kind of hard to find. Someone else will hopefully chime in here...
If your car is OBD 1.5 (which it probably is?) They won't work. The earlier cars used OBD 1 and many of the features are incompatible.
Yes, every LQ1 car is OBD 1.5. I thought there was a way to hook everything up (even if you needed to add sensors?) :question:
nope pcm data streams are different
Not true. My car is an LQ1 and its OBD1. They changed to obd1.5 in 94, at least in GP's.
There are a few people that can make a chip to make it work. I know Gnatgosplat used to but I think there is one or two more that have the capability.
oh well thats fine. the only reason i ask is there was a cutlass at the pick n pull that had one, and i was just wondering.
Jake, when's the next time you're going to the JY?
Grab it anyway Jake, they're hard to come by.
wednesday now that manic said i should grab that
Don't forget to clip some of the wiring before the connector. Get as much as you can. :cool:
Are there any 88-96 GPs in the jy? I'm lookin for a couple tires for my 91, and some other odds and ends.
there were around 7 gp there but only one was a coupe
I was hoping it was at least 88-93. There isn't much I can take from a 94-96 car.
well incase a 88-93 shows up by wednesday what are some of the odds and ends you needed so i can look
Leather AQ9 interior, HUD, DIC, factory floormats, 5-speed cars?, lower valence panels, 245/50/16 tires if they are in decent shape. If you happen to run across a TGP/TSTE, send me a text. I'll PM you my number.
highly doubt anything like that will be there but i will definently check
I have full pinouts and infor if needed i have done this to my 1994 cutlass supreme. I can send pics too. The only features that do not work is the fuel range and fuel economy information. I love mine. PM Me.
For the 3.4 engine a chip can be installed into the PCM for the fuel and ECON info to work, but not with the 3100
