tgk Posted August 24, 2003 Report Posted August 24, 2003 GP LE 1988 - Today I noticed a big puddle of oil under the car, look under the car it seems like it leaks near the fly wheel, trans case side, removed the plastic flywheel cover, engine on, verified oil is leaking from above the tran case and not from oil pan. I didnt get to verify if it is from the oil pump seal, but under the throter area looks wet. Does any one have similar experience? Oil leak after engine start, in my situation it is dripping continuously. Fluid looks like engine oil. Whats the fix? Thanks.. Quote
bluegp Posted August 24, 2003 Report Posted August 24, 2003 Whats the fix? http://www.w-body.com/index2.html -- click on "W-Body Problems" then "Mysterious Oil Leak (oil pump drive seal)" Quote
Mint Euro92 Posted August 25, 2003 Report Posted August 25, 2003 I did that fix to mine today the help from this site was awesome every thing went as said thanks for the help Quote
