webxfx Posted January 25, 2009 Report Posted January 25, 2009 Wow - you guys wheren't kidding, this isn't a fun job... Got it all apart tonight, and most of the oil cleaned up - going to start putting it together tomorrow. Since it this far, going to maybe replace the spark plugs - the ones in there now are AC Delco R42LTSM - do you think they might be the ones from the factory still? Quote
White93z34 Posted January 25, 2009 Report Posted January 25, 2009 how are you going about fixing it? Quote
webxfx Posted January 25, 2009 Author Report Posted January 25, 2009 combo of RTV and Small Block Diss gasket not sure if the gasket will be too thick? Quote
White93z34 Posted January 25, 2009 Report Posted January 25, 2009 you should be just fine. that ought to hold up good. Quote
webxfx Posted January 26, 2009 Author Report Posted January 26, 2009 Its all done - it run's.... Mine is a 96, and I think I'm going to post some pictures cause everything I seen from before doing this was of the pre 95 LQ1 and I think there is way more things to take a part - and way more vac lines in the way. At the same time, since the intake was off I did put in some new plugs - chose something different... Champion iridium - once I get some miles on it I'll let you all know how they are holding up. Quote
