1990cutsupreme3.1sedan Posted August 23, 2003 Report Posted August 23, 2003 hey everyone. this site rocks, so much info so little time. could someone tell me how i can replace the alternator in a 3.1. i had it done a couple years ago at a shop and it cost me like 250 bucks. i want to do it myself this time to save money but i am not sure what is all involved. i know i need a tool to loosen the serpentine belt how do i do this? i need basic step by step instructions cuz i am a dummy. any info would be appreciated. thanks much!!! Quote
NOHC_WBody Posted August 23, 2003 Report Posted August 23, 2003 Insert a ratchet wrench(1/2 IIRC), and rotate the tensioner to release tension on the belt. Then, simply slide the belt off the pulleys. Quote
Robby1870 Posted August 24, 2003 Report Posted August 24, 2003 Disconnect the negative or positive battery cable Insert a 3/8" drive ratchet into the tensioner and pull it, so the belt loosens. Take the belt off. Loosen the bolt on the front-top of the alternator (this is on near the top on the belt side of the alternator) Its a 10mm bolt (I think) Loosen the bolt that holds a big long black thing of the back of the alternator (the black thing goes down toward the head. Just loosen the bolt on the top of the black thing that holds it on the alternator) 10mm Now, take the nut off of the power wire (red). Its a 10mm Now, under the alternator, unscrew the big long bolt (this is what the alternator pivots on). Its a 13mm. Unplug the electrical connector on top of the alternator Take out all the loose bolts and pull the alternator out. Its best if you rotate the motor forward before taking the alternator off. Have fun!! Robby Quote
gp90se Posted August 24, 2003 Report Posted August 24, 2003 FIRST THINGS FIRST, DISCONNECT THE BATTERY [/i][/b] Quote
Robby1870 Posted August 24, 2003 Report Posted August 24, 2003 Disconnect the negative or positive battery cableInsert a 3/8" drive ratchet into the tensioner and pull it, so the belt loosens. Take the belt off. Loosen the bolt on the front-top of the alternator (this is on near the top on the belt side of the alternator) Its a 10mm bolt (I think) Loosen the bolt that holds a big long black thing of the back of the alternator (the black thing goes down toward the head. Just loosen the bolt on the top of the black thing that holds it on the alternator) 10mm Now, take the nut off of the power wire (red). Its a 10mm Now, under the alternator, unscrew the big long bolt (this is what the alternator pivots on). Its a 13mm. Unplug the electrical connector on top of the alternator Take out all the loose bolts and pull the alternator out. Its best if you rotate the motor forward before taking the alternator off. Have fun!! Robby Quote
1990cutsupreme3.1sedan Posted August 26, 2003 Author Report Posted August 26, 2003 i changed out the alternator on sunday, woo wasnt as bad as i expected but that back bolt is a pain. thanks for the above instructions!! it helped big time. thanks! Quote
