dogginred90 Posted January 23, 2009 Report Posted January 23, 2009 I know you guys dont know me here, but I need some help here. The car is a 90 TGP. Ok guys need your help here. I just replaced both my heads. Which we all knw whats involved with that. LIM, UIM,all that other good stuff. Well I get it all back together and fire her up. And she goes straight to the rev limiter. I checked the throttle for bindage, there is none. Disconnected the follow with no cure, Throttle linkage, IAC, TPS, CTS. The only thing that changed it was the MAP, and it just wont run with it unplugged. Any suggestions on this BIG issue. Thanks, Shawn Quote
jake91 Posted January 23, 2009 Report Posted January 23, 2009 i know this doesnt help but post up pics in the members ride section Quote
ManicMechanic Posted January 23, 2009 Report Posted January 23, 2009 Sounds like a MAJOR vacuum leak. Quote
GP1138 Posted January 23, 2009 Report Posted January 23, 2009 Can you take a video of the problem? It would help to know if it shoots straight up or if it walks up. Quote
dogginred90 Posted January 24, 2009 Author Report Posted January 24, 2009 It shoots straight up. And stays there.If I drive it, it goes atleast 40 mph without hitting the gas. Went out and sprayed carb. cleaner around the the upper intake and on the vacumm hoses I can reach. NO CHANGE in idle. I wil have to pull the upper intake off and see if something is messed up under there. Quote
swift13 Posted January 24, 2009 Report Posted January 24, 2009 not sure if this could be the same problem but i put my tps in wrong and it did the same thing right up to 4k rpm but that was on my cutlass and with the dohc. theres my 2 Quote
Andrew Posted January 24, 2009 Report Posted January 24, 2009 Sounds like a MAJOR vacuum leak. my thoughts as well. Quote
GP1138 Posted January 24, 2009 Report Posted January 24, 2009 Check your Idle Air Control for it's presence, but also for the little o-ring around it. I've done that one too. Quote
dogginred90 Posted January 24, 2009 Author Report Posted January 24, 2009 FIXED!!!!!! The rear Upper intake gasket slid part way off. I guess when I was trying to put the PCV hose on. HAHA oh well it is all good now. Thanks guys Quote
