GPdriver1986 Posted August 23, 2003 Report Posted August 23, 2003 Right now both of my a rear rotors are warped because both wheels over heated only once and hasn't done it since the beginning of July. I'll be going back to school soon so i'll have access to the auto shop (my teacher is a GM mechanic and former engineer), I can use the machine to resurface my rear rotors. Should I buy new rotors or should I wait until I go back to school? Quote
Slade901 Posted August 23, 2003 Report Posted August 23, 2003 First, measure the thickness of the rotor(warped) with a micrometer and if the thickness is less than the minimum required thickness then resurfacing it would not do good and better buy a new rotor. Quote
Redfox340 Posted August 23, 2003 Report Posted August 23, 2003 First, measure the thickness of the rotor(warped) with a micrometer and if the thickness is less than the minimum required thickness then resurfacing it would not do good and better buy a new rotor. Agreed. Wait till you have access. However, if you're doing your own work, OEM rotors are cheap and can be installed easily. I say, if you need to save money, I'd turn the rotors at your mechaine shop. - Erik Quote
GPdriver1986 Posted August 23, 2003 Author Report Posted August 23, 2003 The rotors and pads are only 1.5 months old Quote
Redfox340 Posted August 23, 2003 Report Posted August 23, 2003 The rotors and pads are only 1.5 months old Then keep em' if the thickness is still good. Grind / turn them down to level and slap those back on afterwards. You should be set then! - Erik Quote
