Artemis Posted January 21, 2009 Report Posted January 21, 2009 Thats right, took the car in to get scanned today. Hard to find a place around here where they'll scan my OBD 1.5. Anyways, first time I've ever scanned the car and I got 17 codes... although it fluctuated from 17 down to 13 and back up. Mechanic and I agreed it may just be my ECM. Any thoughts? Car was pulsating at idle, we cleaned the IAC and now it idles fine. Quote
slick Posted January 21, 2009 Report Posted January 21, 2009 Are you 100% positive that the ECM wasn't hooked up to power on the bench, and somehow codes were obtained from there, since there were 0 sensors connected???!!! LOL Yeah, I'd gonna go out on a 5' diameter branch here and say bad computer. Quote
1990lumina Posted January 21, 2009 Report Posted January 21, 2009 Could be a poor ground or something to the ECM as well... Quote
Artemis Posted January 21, 2009 Author Report Posted January 21, 2009 15 - Engine coolant temp sensor error (low temp indicated) 16 - System voltage too low 17 - Camshaft position sensor error 23 - Intake air temp sensor error (low temp indicated) 25 - Intake air temp sensor error (high temp indicated) 33 - MAP sensor circuit error (signal high indicating low vacuum) ( dont I have a MAF?? 95 GTP) 36 - MAF sensor error 41 - MEM-CAL error 66 - A/C pressure sensor circuit error (low pressure indicated) 67 - A/C pressure sensor circuit error 68 - A/C clutch relay circuit error (shorted to ground) 69 - A/C clutch relay circuit error (open circuit indicated) 70 - A/C pressure sensor circuit error (high pressure indicated) 71 - A/C evaporator temp sensor circuit error (low temp indicated) 75 - Digital EGR solenoid #1 circuit error 82 - 3x Crankshaft position sensor circuit error 85 - PROM error 96 - Transmission system voltage low 98 - Invalid PCM program Hmm, that adds up to 19... so 19 codes. Quote
Artemis Posted January 21, 2009 Author Report Posted January 21, 2009 I can swap an ECM from any 95 LQ1 W-body right? Quote
95 vert Posted January 22, 2009 Report Posted January 22, 2009 I'd say yes. Make sure part # matches Quote
ManicMechanic Posted January 22, 2009 Report Posted January 22, 2009 CUTLASS 94-95 Elec Cont Module (ECM); 6-207 (3.4L) GRAND PRIX 94-95 Elec Cont Module (ECM); 6-207 (3.4L) LUMINA CAR 94-95 Elec Cont Module (ECM); 6-207 (3.4L) MONTE CARLO 95 Elec Cont Module (ECM); 6-207 (3.4L) Quote
