carkhz316 Posted January 21, 2009 Report Posted January 21, 2009 Are you sure its the high side, or that return/ cooler line? because I know at least for the cooler line, you can take the airbox out and take the fittings out of the rack that way (through the top, then wiggle it out from underneath.) Is this on your TGP, as I'm not sure on the turbo setup, but for sure on the NA 3.1 Quote
Addicted To Boost Posted January 21, 2009 Author Report Posted January 21, 2009 This is on the 91 GP, 3.1 N/A. I am positive it is the high pressure line, I wiped it off and there is a slit in it that is weeping PS fluid. Quote
Addicted To Boost Posted January 21, 2009 Author Report Posted January 21, 2009 What are you guys using to bust these fittings loose from the rack? I tried a regular combination wrench, but it was too long to work. Then I tried an 18mm crows foot and that fit on there better, but this is in such a tight area that I can't seem to get enough leverage on there to bust em loose without the wrench slipping upward off the fitting.. What are you guys using to bust these fittings loose? Quote
1990lumina Posted January 22, 2009 Report Posted January 22, 2009 Can you fit a 18mm stubby wrench in there? I haven't personally changed the lines on a W - but at work stubby wrenches are almost a must have to do power steering lines lol Quote
Addicted To Boost Posted January 22, 2009 Author Report Posted January 22, 2009 I went and picked up a stubby 18mm and that did the trick. New line is in, and no more leaks! Now I get to drive my $200 GP Quote
pontiacmaniac94 Posted January 23, 2009 Report Posted January 23, 2009 I went and picked up a stubby 18mm and that did the trick. New line is in, and no more leaks! Now I get to drive my $200 GP nicely done! when i did my rack and pinion, i swapped out the high pressure hose at the same time because mine has been leaking since i bought the car 4 years ago just for future reference, go to your local harbor frieght store and buy some crow's feet. a set is like 10 bucks, and that will help get in those hard to reach places.... good to hear you got it all squared away! Quote
Addicted To Boost Posted January 23, 2009 Author Report Posted January 23, 2009 Thanks. Actually, I tried crows feet first, and I couldn't get enough leverage on it to bust em loose. A stubby 18mm was the perfect length. Quote
1990lumina Posted January 28, 2009 Report Posted January 28, 2009 Do you know if that return line on your '91 GP is the same as my '90 Lumina? If so, I might want to pay one of you guys to go buy me the return line for my Lumina and ship it to me lol. It blew up again, and I'm not going to piece it back together this time - just want to replace the whole line. GM discontinued it, and the only place that sells something other than bulk hose for the return was Napa. They are ordering me the part, but I have a feeling it isn't the correct one. Quote
Addicted To Boost Posted January 28, 2009 Author Report Posted January 28, 2009 It ends up ~$28 with tax included for the line. http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=PWR&MfrPartNumber=91911&PartType=19&PTSet=A Quote
1990lumina Posted January 29, 2009 Report Posted January 29, 2009 It ends up ~$28 with tax included for the line. http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=PWR&MfrPartNumber=91911&PartType=19&PTSet=A I believe this is the picture I saw from Napa too so I may have the right one coming lol - I sure hope so. Thanks! Quote
Addicted To Boost Posted January 29, 2009 Author Report Posted January 29, 2009 No problem, keep us posted Quote
