I am trying to replace my wheel hub on my impala. I got all the bolts off and the big axle nut, off after much sweating and cursing, but couldn't get the hub to separate. So in my angry frustrated stupor I started prying it off and it started budging or so I thought, the outer cv joint was budging and came with it.
I know I am going to need a puller to separate the hub from the axle. But I have never done anything with a cv joint. How do I get the cv joint put back in right?
Thanks in advance
Thanks in advance
Step-by-step I have done this countless times
19mm socket, remove wheel
2 18mm bolts, remove caliper bracket with caliper attatched
Hold caliper assy up with whatever to strut
Remove rotor
Remove axle nut, 35mm
Thread axle nut socked on a tad bit to keep from damaging threads, hit with hammer to break axle loose in hub
Remove 3 13mm bolts holding hub to knuckle
Unclip ABS sensor plug and unplug
Hammer out hub assy, best if hammered on the backside to the side. A airhammer may be neccessary
Once loose, hit end of halfshaft again to drive it outta hub, remove hub from knuckle..
And like I said, a airhammer may be NECCESSARY.. The hubs love to corrode to the knuckle.
hey thanks 1loudcutty
putting the nut back on the axle and hammering it did the trick that is where
I was having trouble
thanks a lot
