GPdriver1986 Posted August 22, 2003 Report Posted August 22, 2003 Ever since I had my car (June 2003) the odometer/trip has not worked. I took apart the cluster, the gears are fine, I spun the gears forward and the odometer counted the km like it should. I was looking at a GM service manual for the GP instrument cluster, according to the circuit diagram, the IC chip controls the odometer/trip.Right now my low fuel light flickers sometimes and my temp light stays on constantly. I wonder if I have a broken motor or my IC chips needs some solder? Quote
Slade901 Posted August 22, 2003 Report Posted August 22, 2003 Re-solder that IC (Integrated Chip) first and see if that works. It is one of easy task you can do to narrow down the problem. Quote
GPdriver1986 Posted August 22, 2003 Author Report Posted August 22, 2003 Does it say on the chip IC? because I have a base cluster and the last time I checked I couldn't find it. Quote
