tickin in 2.8 found
Found my tickin noise in the 2.8 i rebuilt--Darn injector---cleaned it so well i got all the junk out of it an started tickin at me :lol: so i no longer need to swap out the 2.8 pushrod(2.8 to 3.4 or bigger)--Thanks to all who helped with the suggestions
Cool! When did it do the "ticking" noise? Because when my engine is HOT, and I start it up, it will start to make a "ticking" noise until I start to leave and give it gas...
is this ticking noise bad? can it cause a car to idle extremely ruff and barely run at all? my sisters car wont idle right and u can smell gas and there is a ticking noise that is almost constitent but stops everyonce in a while.
I was going to say injector until you told me it didnt increase with rpm. Injectors should have a slight tick to them, its only when the ticking gets louder is it time to change them.
Robby
got the injectors to stop tickin,now the new crank an rod r knockin again-tourqe them down to proper tension an still knock
got the injectors to stop tickin,now the new crank an rod r knockin again-tourqe them down to proper tension an still knock-new oil pump also-
:evil:
