Where would be a good place to find new brake lines for a Cutlass convertible, and will coupe/sedan ones work? I am thinking the ones from the front to rear.
You mean the hardlines? I'm pretty sure those aren't available anymore pre-bent. Either find them from another car or make them yourself.
Your best bet is to just buy a spool of the same size line from the auto parts store and take your old ones off to use them as a template to make the new ones from.
I believe coupe and sedans use the same lines. not for sure though.
any gen 1 car could be a donor.
which part is bad?
