I've heard of these somewhere but can't find where to get them? Do you press the poly bushing into the bracket or is it the entire assembly?
Ya, it's the dog mounts. This is on my 96 GP so it has 2. Just finished putting a new oil pan gasket on(PITA!!)...noticed water pump gasket is leaking and power steering pump also, so while the frame is lowered that's next. The engine mount was kinda smashed on the rear side of it, so i think the dog mounts are worn out.
if has the wishbone style ones, the ones that anchor to the radiator support with 3 bolts, correct?
which part is bad?
if is is the small bushing at the rear, then replace em.
if is is the large "square" ones at the front... rotate em 90 degrees!
Do you press the poly bushing into the bracket ?
yes. the hardest part is getting out the old bushing.
